help with error code 12
I just finished putting in the TPI system in my 86 camaro that was carb.
any how I got it all started up today but the check engin light is staying on
so i turn the ign on and jumper the pins on the aldl
the check engine light flashes 12 (No reference pulses to ECM ) correct?
what does this mean?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
A code 12 is pulled everytime you do that. If that is the only code you shouldn't have a check engine light.
1989 Formula 350
1989 Formula 350
I just found that
but the light is staying on
does it flash one code then another
it just keep flashine 12
also if the car is running it just flashes continuosly i this normal?
forgive my ignorance this i my firs experience with this (TPI THAT IS)
thanks
Objects in mirror are more stable than they appear
www.members.home.com/v8power
4BBL to TPI in the works
86 350 5spd
E.E.T (Electronics Engineering Technologist)
thanks
86 350 5spd
ok i got it now
its chucking error 33
any thoughts?
86 350 5spd
any thoughts?
86 350 5spd
Yea
but I got it fixed last night
it was the analog ground pin "B" it was pushed back in the connector
![](https://www.thirdgen.org/messgboard/smile.gif)
86 350 5spd
86 350 5spd
