383 TPI...What Cam?
383 TPI...What Cam?
I plan on swapping a 383 TPI for my 305 TBI. I've never built an engine so it will be my first time but I'd like to do things relatively, "Right". I've heard that you have to get a cam that makes the computer happy, BTW I have 91 RS. So what exactly is the best cam for a 383 TPI. Thanks in advance for any help.
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I am in the process of building a 383 SuperRam car. Here is the setup I decided on...keep in mind...the cam you choose should compliment the heads you choose.
- Rebuilt 383 with forged flat top pistons
- AFR 195cc aluminum heads
- LT4 Hot Cam
- Super Ram intake setup
- 1 3/4" SLP Headers
I am looking at around 10.1 compression....probably about 480-520hp(??) Should get me low 12s or high 11s...and will be a daily driver. But I, along with many others (those who convinced me) highly recommend the LT4 Hot cam.
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
3" Flowmaster Exhaust System w/Quad Tips
Aiwa CD/Mp3 player
10 Disc CD Changer
Rockford Fosgate Speakers
SLP Headers Coming
Dynomax High Flow Cats Coming
More to come.
[This message has been edited by mult68 (edited September 14, 2001).]
- LT4 Hot Cam
1992 Teal Camaro RS
T-Tops
305 TBI V8
Open air element
Aiwa CD/Mp3 player
10 Disc CD Changer
SLP Headers Coming
More to come.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Speed density or MAF? Either way, I dont think it will run at its full potential with a stock chip.
The LT4 HOT cam is a good choice. So is the LPE 219 cam.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
<font face="Verdana, Arial" size="2">I dont think it will run at its full potential with a stock chip.</font>
Engine: 305 TBI
<font face="Verdana, Arial" size="2">Originally posted by u r sofa king we tah did:
100% true. which intake are you going with, long tube runner, super ram, or mini ram? if your going with the super ram id run the LPE 219. i have the LT4 hot cam waiting to be installed, but im going to siamesse my manifold and runners at the same time so it will pull past 4800rpm.</font>
So is the super ram the better choice. I don't know much about TPI.But it sounds like the super ram w/ the LPE 219 cam is good set up. Thanks for narrowing things down guys. Oh yeah, I am going to have a custom chip made.
I am running a long tube 383 tpi with 9.6:1 compression, edelbrock alum heads, and a 204/214@0.050 .425/.440 lift 112 lobe seperation hyd flat tappet cam. I really love the powerband, but it took 20 reburns of my EPROM to get everything right. My engine is in a 4x4 Jeep with 35" tires so I wanted strong lowend torque and a smooth idle. It pulls real strong up to 5000rpm right now with stock runners, but I am changing to AS&M large tube runners shortly for a little more pull on top.
Dave Zelinka
Dave Zelinka
