Can a side mounted TIMING POINTER be used instead of the stock CENTERED timing tab ?
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
I just converted a friends 87 SS to TPI, and 88-92 SERPENTINE setup. The problem is I forgot about that center mounted tab on the stock timing cover. When it came to setting the timing, I couldn't see the timing mark, because of the serepentine assembly. I'm accustomed to installing a FLUID DAMPER unit with a fluid damper pointer, along with a newe cam, but this time I wasn't doing a cam swap with the conversion, so I totally forgot about the STOCK CENTERED TIMING TAB. Can I just simply install a side timing pointer, and set the initial timing? RSVP anyone. Thanks to all
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed/1-3/4" full length headers/3" X-PIPE assembly/ 8.5" G-80 rear with 3.73 gears.
http://community.webshots.com/user/ssynergy
www.y-t-g.com/88monte
Car: 88 Monte SS
Thanks BRENT, I figured the first answer was my best solution. Thanks again buddy. I will just have the owner get a new TPI unit with pointer.
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
Go buy some timing tape and place it on the balencer and make it correct for your timing tab.
A black felt works too ... for cheap guys like me who would be too pissed off to change the balancer.
Mark.
Mark.
my crate engine came with the center timing tab, i put it in my 89 L98 with the serp. belt, its a pain in the *** for me to see the timing tab, but if i look around enough i can see it to time my car so i know its not impossible.
1992 Trans Am
05-10-2023 07:19 PM
Terrell351
06-13-2021 01:13 PM
