What kind of gas milage you guys get?
Hey I have a 305 TPI 5 speed Formula. I took it up to my friends house for the Penn State game and to chill with him. I had 330 miles round trip and got a little over 23 MPG. I didn't think it was too bad considering a lot of it was back roads to avoid construction, I drove around some up there through town, and I was having a little fun blasting up a mountain at 95 mph in 4th. I was just wondering what you guys are getting on the highway to see if I'm on par. I may be taking my car to Richmond for the race. Thanks everyone.
90 Formula 305 TPI 5 speed
K&N, Dynomax Muffler
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Around 24 if I stay out of it. 3.23 geARS and .62 od help.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
1991 Firebird
AFPR,Lakewood lcas
AFR 190s
autopower rollbar
Car: '89 TA
Engine: LB9
Transmission: M5
21 mpg with mostly highway, 25-28 with all highway, and 18 minimum with lots of city driving.
305 tpi 5-speed w/ 3.08 gears
19-23 with both city and highway, i live outside of town (UNTILL NEXT WEEK).
and that is on a modified 350 with 3.27 gears, not bad. that is why i love fuel injection.
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Dupont Flame Red Hardtop/ Grey Interior
Working at Carl Cleve & Sons Auto Body Repair as the wetsander/buffer.
1991 GREY S10 2.5L/5SPD -FOR SALE.
Jarrad
TH-700R4
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I get a nice 23.5 MPG all highway
about 18 in the city
On average I get around 20
I went from 18 on the highway with my 4bbl
Granted I have a 3.73:1 gear as well.
My 1990 Riv gets about the same, it weighs about the same, and its only a 6 cyl. I can't complain about my fuel milage on my Formula.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
Car: 1987 GTA
Transmission: 4L60e
17 mpg no matter how I drive (including a whole tank under 2200 rpm). I've changed the oxygen sensor, fuel pump (this dropped my mileage from 19 to 17), fuel filter, and properly aired up all 4 tires. I have NO clue what is causing this bad mileage, but the car runs great.
~3.1EyeCandy~
"The Car that started my craze"
'92 Firebird 3.1 (A car sold)
My new baby: '87 flame red GTA 350 w'auto, ported and polished plenum, custom cold-air intake w/K&N, 180* thermostat, Hooker SuperComp Exhaust, Splitfire plugs, Hypertech Airfoil,
Carmine interior with pioneer all around
My Cars
jonathan_badgett@yahoo.com
~3.1EyeCandy~
My Cars
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My best was 26 on my modded 350 TPI usually its around 21 though.
89 FORMULA 350
99 Grand Prix GT
89 FORMULA 350
99 Grand Prix GT
I have been getting great gas mileage since I put the 3:70 gears in my car, a ton better than when I was running 2:77 gears (no, this is not a typo). The engine does not need to work much at all on the freeway, and it seems much smoother around town. I run 2100 rpm at 65 or so mph and have been getting anywhere from 27 - 29 mpg !! The best of both worlds! power and economy. Who needs a Honda? 8^)
1991 Camaro RS/Z28,polished TPI, 355ci. Sportsman 11 heads, LT-4 Hot cam,Pete Jackson gear drive, on,and on, and on... best E.T.>13.4 new best MPH> 108.7, no traction, no tuning, The car is pictured in Chevy High Performance magazine, June 2000 issue.
http://www.geocities.com/jasonsz28us/INDEX.htm
1997 GMC Yukon, 4 wheel drive, leather, loaded, Gibson exhaust, K&N intake, Boston pro series speakers..... That's it so far.
1969 Camaro,12 point cage, total project right now, I am planning an LS1 - T56 - and a Vette independent rear. Pro Touring crowd, look out! 8^)
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
With my combo I get 15 mpg in the city and I got a best of 21 mpg on the Autobahn. That was cruzing at 90 and many runs up to 130 mph.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.6/1.52 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, Accel 300+ box & coil, Taylor 409 wires, Fastchips custom chip, MAC sub frame connecters, Lakewood LCA & Adj. Panhard rod, SLP 2500 stall, 3.42 rear gears, 1LE aluminum driveshaft, white face gagues, and NOS!
