was really excited about TPI swap now reconsidering please help
Car: 1983 Z28
Engine: 6.6L 406
the more and more I have been reading from people the worse it sounds. is it true I have to replace the wiring that goes behind my dash over to the instrumentation? Also does it NEED the charcoal canister? Iw ould like to do without it just for the fact that my engine bay us very clean and I want to keep it that way.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package , dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, 16" IROC rims and ASCD SS hood.
future mods:
SLP headers, completely done over suspension, black paint with flames, NEW PLAN IN THE MAKING:
BUILD A WILD CHEVY 302 JUST LIKE THE ORIGINAL Z28 HAD
future mods:
1 Post
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I didn't replace any wiring under the dash, though I did have to fish a few things out to connect my painless wiring harness. Thinks like the ALDL connector, the neutral safety switch, fuel pump relay behind the driver side kick panel and a few other things. The instructions were easy to follow. My 89 RS 305 TBI already had a canister. I bet you could pick a canister up from the junk yard for next to nothing. Not a part in very high demand. If you bought some other parts they would probably throw that stuff in for free. TPI conversion is not easy but I think it is well worth the effort if you are looking for the benefits of fuel injection.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
Car: 1983 Z28
Engine: 6.6L 406
you went the painles wiring way? I have heard that may be better than trying to use the OEM harness. is that true?
future mods:
future mods:
1 Post
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by super83Z:
</font>
</font>
You don't have to run a Cc Canister just because you have TPI.
You might research the varioust years and ecms they used for making an informed decision about what to run ecm wise
Using a Painless wiring harness is only better if one or more of the following are true:
A. Your are an installation shop that finds it cost effective to install a new Painless harness instead of cutting and splicing the old one.
B. You are an electrical novice who is uncomfortable with trying to integrate a FI harness into a car that is not a Camaro or a Corvette.
C. You are an electrical novice who is uncomfortable with trying to repin the harness for a different computer.
D. You are in a hurry to get this done.
E. You are not willing to research what it takes the do the job correctly.
Basicly since you are installing this in your own camaro I think you are fine with the GM harness. The only advantage provided by the Painless harness is step by step directions. To make installation easier you should probably try to find an 86-89 unit. This will allow the fewest changes to the harness. You can integrate your factory VSS into the TPI system. You can also use the factory ALDL and SES light from your 83. If you have a light driver module then you will have to bypass it. With your list of proposed mods you may not want to use a MAF since it could be a restriction. In this case you would need to find a 90-92 harness or repin whichever harness you have. You should also think about what you will do for a chip. There are many on this list who can coach you on burning your own.
I guess what I am trying to say is do all of your research before you commit $$$$$ to this project.
John
Heart of Texas Power and Performance
John
Car: 1983 Z28
Engine: 6.6L 406
My car was originally CFI. Would this make a difference? I took it out because of the fact that someone before me hacked it to pieces.
future mods:
future mods:
Car: 1990 GTA
Transmission: manual/t56
I'm doing this swap myself and I found that it was easier to use a stock gm harness. My car is a 89RS that used to have a V6. I swapped in a 350 and bought a engine wiring harness for a 89iroc and it went right into place. plus all the connectors were the right lenth to go exactly where they were supposted to so that made it a little easier to hookup all the sensors and other items.
Car: 1983 Z28
Engine: 6.6L 406
That is a good point that they will be the exact right length. Well whats the harm in trying right? I just hope everything finds a place.
future mods:
future mods:
Car: Take
Engine: Your
Transmission: Pick
I didn't like using the Painless harness, and If I had to go back and do it again, I'd use a GM harness out of a wrecked car or something.
I didn't use the Charcoal canister either.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Why do you want to convert to TPI? Don't you like top-end power?
'89 Firebird Formula 350
L98, WS6, Red/grey, t-tops, and a 3.27:1 rear
K&N, TB bypass, no MAF screens, CAI, full Accel ignition, no cats, Hooker Supercomp shorties, Hooker 3-inch catback
ET? 14.8 @ 93mph
Also own '83 Firebird 2.8 2bbl. 155K miles.
ET? Break out the calendar!
ET? 14.8 @ 93mph
Car: 1983 Z28
Engine: 6.6L 406
I want drivability and MPG's. Also I want more low end power. Plus if I ever get the craving for more top-end then I will just get a superram
future mods:
T-56 almost ready to go in, TPI swap coming up
Wifes new car:
95Z28, AT, leather, T-tops bone stock for now.
future mods:
header to tailpipe replacement and a cold air intake. Then I am just going to leave it alone
future mods:
Wifes new car:
future mods:
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I LOVE my TPI conversion, now granted I bought the WHOLE DONER car from the Salvage yard. that way I got EVERYTHING I needed.
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
John
5.1 TPI Automatic
83 Camaro (Parts)
83 T/A (parts)
Car: 1983 Z28
Engine: 6.6L 406
yeah hopefully everything will go good with my swap.
future mods:
Wifes new car:
future mods:
future mods:
Wifes new car:
future mods:
Sanjay
08-12-2015 03:41 PM
