How can I make this hood functional??
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Well, I have to replace the hood on my Camaro, because someone hit my car. So, I'm taking the ram air hood off of my dad's Camaro, and I want to make it functional so I can have a nice ram air. I have a TPI in my car, and there are holes in the black grate so air can get through there. Any ideas? I was thinking of just mounting one of those K&N cone filters to the end of the throttle body, but I'm not sure if it will fit. Go to http://www.geocities.com/camarox84/ramair.html to see the hood. Any ideas greatly appreciated. Thanks.
1984 Camaro Sport Coupe - Rebuilt 355 S/D TPI L98, Crane 2032 CompuCam, Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
1992 1LE B4C Police Camaro RS - 305 TPI 5-Speed
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
Car: '92/ 25th anniversary Z28 ragtop
Engine: 305ci
Axle/Gears: 273:1
<font face="Verdana, Arial" size="2">Originally posted by CamaroX84:
</font>
</font>
The first idea is to use a Corvette air box/filter cover,(it's like a single version of the Camaro's dual air filter intake snorkel),placed upside down with the 'vette snorkel hooked on your TPI.The 'vette air filter would go on the "mouth" of the filter box or on the opening under the hood
The second idea is to make your own air box out of sheet aluminum from the "mouth" of the TPI opening to the opening in the hood. The bottom of the box would be flat and the sides cut to follow the line of the hood. The top could be flat also,going up to the underside of the hood. At the TPI "mouth" you put a K&N cone/oval filter.
If you want I can send you some drawings of these two ideas,granted I'm no Rembrant but it would be easier to "see" the finished idea than to explain it.
![](https://www.thirdgen.org/messgboard/cool.gif)
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
what about modifing a factor ram air setup from a 4th gen Camaro?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
you can only use the cone air filter on the throttle body is you have a speed density TPI 90-92. OTherwise, you have MAF and you cannot put a conical air filter on, for it will rid u of your necessary MAF.
1989 Chevrolet Camaro IROC-Z
L98 - 350c.i. TPI, rebuilt 700R4 auto w/shift kit, Dual catalyst Monza PaceSetter Cat-Back, SLP 1 5/8 Coated Headers, 3.23 Posi rear, Hypertech chip with 160stat, Under-Drive pulleys, AFPR, K&N's, !Air Box w/ Ram Air, moddified MAF, !TB Coolant, Spohn Dual Cat SubFrame Connectors, Alarm, Keyless entry, remote starter, 92 Z28 AeroWing, Brand New Paint (6/21/01)
Future: ZZ4 TPI w/EGR, T56, 3.42 or 3.73, Spohn strut tower brace and LCA's
1989 Chevrolet Celebrity Eurosport
2.8 MPFI, no mods
225,000 miles and still ticking!
More info and pics on my webpage:http://go.to/iroc-z
AOL IMer: GPA 0point0
2.8 MPFI, no mods
colton_carlson
03-08-2019 12:21 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
mustangman65_79
08-11-2015 03:17 PM
