Lt1 cam 1.6rr ???
Re: Lt1 cam 1.6rr ???
Given that the cam provides lift in the .440-.450 range with 1.5s that would put you up around .480" with 1.6s rockers. That's definitely near the danger zone with stock unmodified heads.
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
it is but its not. dont forget a new decent set of springs and retainers. and a shim kit. u should be fine. many have done it. im a 499 lift with my comp cam and 1.6rr's stock 305 heads.
Car: 1991 GTA trans am
Engine: 305 tpi
Ok well I guess we will try it and see what happens....
Between that and the chip tuning I dont know what to worry about more...
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
I have heard .480 is where stock retainer will hit the valve guide boss and/or valve seal. running .050" offset locks and shims will raise that clearance to almost .530" safely
Car: 1989 T/A
well with just the cam swap, which is a very common mod on any 305. u shouldnt need any burning. just an AFPR and up it a little.
that is what i did.. i actually just picked up some crane gold racing 1.6rr's to replace to chepos i have on there..
did you run shims and offset locks or offset retainers? thats the only way i know to run higher lift than .480 on stock heads without machine work.
Car: 89 Iroc-z
Transmission: TH400
with speed density, aka 91-92 cars and some 90's i guess, you will need a tune. Even small cams wont be optimized running stock programming. Depends on how big you go tho, you can get away with cams like the comp cc501 which is a 212/218 cam, just a step and a half up from a stock LB9/ L98 grind. a Mass air car can tolerate mild cams much better tho
New2Chevy
09-28-2015 12:35 AM
