Retrofitting TPI
Retrofitting TPI
I was wondering if it is possible to retro fit the TPI sytem off of a speed density trans am on to a chevy 327 we are going to change it to a hyd. roller cam I would like to know what we'll need and where do the sensors go. we figured we would need the ECM,wiring harness,high pressure fuel pump manifold,runners,plenum,throttle body,fuel rails,injectors,new fuel lines, an ecm,tps,mat,knock sensor,oxygen sensor,iac we know a few sensors go on the throttle body and the oxygen sensor goes in the exhaust manifold we would like to know exactly where each one goes and if wemissed any thing. I know it's a long and complicated post but any help would be appreciated.
Yes it can be done. Very popular with the street rodders. Check out:
http://www.jagsthatrun.com/Pages/Che...I_TBI_V-8.html
http://www.painlessperformance.com/fuelinj.htm
http://www.fuelinjection.com/
http://www.howell-efi.com/wiring_kit...tpi_index.html
Sanjay
08-12-2015 03:41 PM
