MAF Sensor going 1000CFM, what's the point?
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I was thinking about this and figured I'd put it out there to see what you guys think.
I've been hearing that a high flow MAF equipped TPI can only handle about 400 or so hp before you start having problems,. I've heard that you can't even re-calibrate the computer and have the MAF work effectively without some problems at those hp levels. From what I'm told, the right way to run above the 400hp mark with TPI would be to switch to a Speed/Density type system. So, what's the point of a 1000cfm MAF if you can't use a MAF system at those hp levels?
The reason you can't use the MAF over 400hp is because it wont flow 1000 CFM.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
48psi regulator, (Nickel method)
Rob
'86 TA 305 TPI
Edelbrock T.E.S.
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
We all need to bug granatelli or paxton or whoever it is that is making those oversize MAFs for the 4thgen guys to hook us up. Car Craft had an article a while back that showed a working one they had done, but it was a one-off deal at the time.
Dan
87 IROC-Z, 6.7 $uperram & cam, Eagle 5.7" rods, Dart 200cc Iron Eagle heads, auto w/ BTE 3000stall lockup, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" headers, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback.
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear - FOR SALE
Dan
Well this subject has been gone over and over and ovaer and ...............
Anyway I hope Glenn gets into this one cause I can't explain it as well as him but here goes.
True the MAF flows only so much air but that is not the limiting factor. The cal maps for the prom only got to 255! Now flowing more air can be done but the prom needs to have a value to reference it and as it is now it doesn't.
So the problem tends to be with the prom and ecm.
I know Vader was trying something but then all went quiet about it when he said he had a working model on the bench testing. I guess you need to be in the click .
Hope it helps, but really it won't I know.
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
(stock intake, runners and suspension)
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
Engine: Chevy ZZ4
Ok, so there is possibly a way to make it work but for all our purposes when running a MAF sensor the bigger MAF's and the 1000cfm throttle bodies are basically a waste of money. Looks like I'll have to do what I had originally planned for the future which is going to the speed/density setup.
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
