how to test fuel pump or find short
My fuel pump does'nt buzz at all when i put the key in the on postion,Im pretty sure the relay for it works because it clicks when i put the key in the on position.But how do i find out if the pump is bad or if it is just a short somehwere.Thanks for the help
yeah the car starts right up and seems to run fine but it keeps popping code 54.The service engine light only comes on about every othere time i take the car out.I unplugged the batt to reset the comp but the code comes backup.any ideas??thanks
Unplug the connector to the fuel pump relay and look at the contacts. Mine were not making good connection and caused the same symptoms you are having. I found replacements at Pep Boys for 3.00.
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
<font face="Verdana, Arial" size="2">Originally posted by DaveV85iroc305TPI:
Unplug the connector to the fuel pump relay and look at the contacts. Mine were not making good connection and caused the same symptoms you are having. I found replacements at Pep Boys for 3.00. </font>
Don
1985 T/A WS6
Recaro Seats
58,000 smiles
TPI T-Tops
3:27 Posi
My Ride
theshackle
03-05-2017 06:37 PM
92camaroJoe
08-13-2015 06:07 AM
