406 Superram- Cam and heads question
I have a 406 sbc and the superram intake. I'm in need of a roller hydr cam and aluminum heads(AFR). I also have a paxton for it. Any ideas on cam and head sizes?
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i've heard the 195's are good as well as the 190's tfs twisted wedge heads flow a compareable amount also as for a cam thhe list goes on and on fortthat big inch motor you'll need a healthy stick maybe 240+ on the duration i haven't used one of their cams yet but tpis makes em givetthem a call for a catalog
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catbcak.
EVRYTHING IS FOR SALE WITH THIS CAR (EXTRA ENGINE,TPI INTAKES,ECM'S,ETC.
GETTING OUT OF THE 3RD GEN MARKET BEST OFFERS
CONSIDERED
CONSIDERED
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
I currently have the trick flow heads and had them ported,and running about the same c.i. you are but I wish i had gotten heads in the 200 to 215 range. I think the 400 would love them with some decent gears to keep the velocity up.If not t.f.'s well work fine.I think t.p.i.s. is over rated in the cam area ,c.cams have a great selection to choose from.Btw afr will confirm the higher ports for your 400.good luck!!!
87 IROC WITH 409(.040 OVER400) MINIRAM,NOS(125HP)TRICK FLOW PORTED HEADS,C.C.CAM,FLOWTEK HEADERS,CUSTOM PROM,MODIFIED 700R TRANS,2400 B&M CONVERTER,3.73POSI REAREND.
LOOKING FOR THE 11 SEC. ZONE.current ets.12.39@114 mph
i dont know what kind of psi your supercharger runs at...but i had a paxton sn93 i think it was 8lb (is this correct gurus) and that was rated on a 305, a chick at paxton started getting into static pressure and flow vs. dimension... (she sounded like an engineer for the company)
but anyway she told me that on a big inch motor (i tried it on a 409 but didnt run it long enough to tune it) it would only create about 1.5-2 lbs of boost. so weather or not she had her head in the sand or not...it sounds reasonable..so get a good high pressure or else i would say its not worth runnin it on big inches
theres my $.02
http://people.ne.mediaone.net/gdm
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
theres my $.02
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
