would leaded fuel damage the O2 sensor?
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I put Cam2 110 octane fuel into my '87 IROCZ.
I have no cat, but I wanted to know if
1) is Cam2 fuel leaded or unleaded?
2) would leaded fuel hurt the O2 sensor?
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, 24#/hr SVO injectors, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, my custom chip, Lay Ind. ram air kit, SS Brakes 1LE upgrade 12" rotors dual piston calipers, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter, next mod: 4.10 rear gears
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
noy sure but i think it is leaded. where did you buy it? ask them. and yes it will damage your o2 sensor. i dont know if 1 tankful will, or 10 tank fulls or just a tiny amount but it will screw it up if it is leaded
http://people.ne.mediaone.net/gdm
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
