daniroc-z, kevin, all others, LPE CAM??
Location: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
I was told to get this cam by a few heavy hitters i race with. SBC 305-383
LT1, L98
211/219
.499"/.525"
.533"/.560"
112
74211
It is a lingenfelter/accel grind.I know of one fellow racer, a 91 350 auto 3.23, with this and she is running 13.6 all day on an otherwise stock motor. I have heard about the LT4 and the COMPU CAMS, but i i don't know which to go with. Also TPIS has a "like" cam i am looking at. Please point me to the right one. my sig show what i have. I am going to boost eventually, but for now i want a low N/A 13 car. Also i am looking at WORLD PRODUCTS S/R TORQUERS for heads. thanx to all THE SHAGGY IROC
'89 SHAGGY IROC
L98, W/C T5, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc. 14.4@ 98.8 MPH w/t-5, can't wait for to install my 3.27 B/W.
so much to do , so little money
[This message has been edited by irocnroll89 (edited July 28, 2001).]
LT1, L98
211/219
.499"/.525"
.533"/.560"
112
74211
'89 SHAGGY IROC
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I think that's the superram grind for a hydraulic cam. check that pn on lingenfelter's website to make sure. are you getting a superram?
Dan
87 IROC-Z, 6.7 $uperram & cam, Eagle 5.7" rods, Dart 200cc Iron Eagle heads, auto w/ BTE 3000stall lockup, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" headers, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback.
1987 Camaro Z28 - 5.2tpi, auto, 3.73s, ram air, airfoil, ported plenum, !cat, !tbcoolant, !smog, !4th gear - FOR SALE
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N - SOLD
Dan
Yah, thats a decent cam. What price are you getting it for?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Those LPE Cams are good in the fact that they are desigined specificly for our TPI cars, comp cams and other such companies make them for just general SBCs, usualy built for a carbed 350. I would stay with a cam from a fuel injection performance company like SLP, LPE or the GMPP cams. I got the LT4 HOT Cam for $165, its a big one though, 218*/228* @ .050 with .498" lift on both sides. But if you get a set of Trick Flow heads (I would't go with the torquers) and use a superram or miniram intake, its ideal. The cam was desigined for short runner intakes, not the long runner TPI set-up. But the same goes for that LPE Cam you are suggesting.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, LPE High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Stay away from the Crane compucams, they blow chunks.
Get the LPE 74219 cam for N/A and if you boost it later Accel has a 215-220 cam on a 115 lsa that's good for boosted motors.
Yes, that LPE cam is pretty nice
I still don't have any times with my setup... I'm fouling the number 6 plug still so I've only been running on 7 cylinders as of late... I've checked everything and have determined a bad ring.
I may take it to the track to see how it runs with 7cylinders
Brendan
1987 IROC-Z L98,SR,EB 6085's,LPE 219/219 SR Cam, Crane 1.6RR, EB TPI Base, 58mm TB, Stock T5, 30lb SVO, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, Aluminum DS, 94 Disk Rear, Adjustable Prop Valve, Precision 3.73 Gears, Weld in Sub-Frame Connectors, Hotchkis LCA's, KYB Shocks/Struts, Poly Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm, Big stereo, 730SD Conversion.
To see the ROC, Check out the webpage Here
Brendan
they want $315.00 for it, i will keep the tpi as is, with minor upgrades. Like i said the guys in the club swear by this cam for both the l98 and the lt1. I know the LT1 guy that sold it to her ( the L98 girl) for $150.00 And her car goes like a raped ape. Shaggy Iroc
Yeah, I totally agree with Kevin, the price of all the GMPP cams is great, and they are cams just like SLP, TPIS, LPE, nothing special, you just pay for the names.
L98 TPI 350 (5.7L)
L98 TPI 350 (5.7L)
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
845?? naw, be the big man and step up to the 847. It's gonna be that or the cc306 for me.
But then again, I'm building a 383 with nearly 300cfm heads and a mini-ram.
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
http://www.geocities.com/mustang_tbird/codypage.html
Cody "cyZ28" Young
