torque specs on intake manifold
1 Post
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
what are the torque specs on the intake manifold for an 87 TPI setup? my book says 30 but i'm not sure cuz later on it says 68 for 88 and later TPI so i just wanna make sure
thanks
Andrew
thanks
Andrew
Car: 86 T/A
Engine: 5.0 TPI
http://www.gmtips.com/3rd-degree/
Enter Site
Choose Tips
Choose Torque Specs Article
I think it's 40~45 lbs.
Enter Site
Choose Tips
1 Post
Car: 87 IROC
Transmission: 5spd
ok so i put it at 30 is that gonna give me problems? i really don't want to take it all off again but if i must i guess i will.
Andrew
Andrew
Should the throttle body be torgued to the Plenum? I had mine off the other day because i was going to port the plenum but then I didn't. I don't have a torque wrench so I just put the bolts on as tight as I could. Is this bad? The car didn't seem to run any different.
1 Post
Car: 87 IROC
Transmission: 5spd
its like 15-20 ft/lbs on the TB to Plenum. if its tight it won't do any harm. there is no strong flex or pull on the TB/Plenum connection so its not a big deal
Andrew
Andrew
http://www.racer-x.f2s.com/proc/torkseq.htm
follow the tpi torque sequence article to find out the correct way to bolt them down.
Car: 86 T/A
Engine: 5.0 TPI
Smokin ~ I don't think 30# will give you any problems BUT if you ever get a code 44 Lean Exhaust check the manifold bolts first.
Proper torque into aluminum IS a big deal less' your real handy with an extractor and tap & die set.
If you're flying by the seat of your pants I've always found that resisting that last little urge to get it "just a bit" tighter........ is a good thing.
Car: 88 Firebird WS6
Make sure to go back and re-tighten them in a week... Odds are they will only be finger tight no matter how much you tightened them down the first time...
1 Post
Car: 87 IROC
Transmission: 5spd
well it wasn't tight enough for the stupid rear part to seal and it leaked oil from the intake/engine meeting point. so i get to take it off and do it again
Andrew
Andrew
1 Post
Car: 87 IROC
Transmission: 5spd
no i used silicone it just didn't squish the right way and got pushed out the back. it didn't get squished towards the inside keeping it in place.
Andrew
Andrew
ambainb
04-25-2016 09:21 PM
