need help!!!diagnostic knowledge
Old 07-22-2001 | 03:31 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
when i connect terminal c(A.I.R) on my aldl with terminal b(Diagnostic) the engine goes into a special mode where the idle stays at 1050 rpm's thereason i ask is i'm having trouble stablizing my idle but when these are jumped it runs perfectly.also when i disconnect the two connections on the emissions box above the airpump the car also runs alot better anyone got any ideas.i was told thhat during certain modes the computer sometimes locks the est into 22* total advance however this doesn'tt occur in this mode .all answers welcome
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catback,a/c delete.
shooting for 13's!!!!!!!
14.10@97mph w/2.01 60'(auto ET)
slp catback is finally on!!!
fastchip prom is in.
kicks you in the *** at wot.
FLOWMASTER S.U.C.K.S
Old 07-23-2001 | 12:11 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
c'mon guys need help on this.......
kicks you in the A.S.S at wot.
Old 07-23-2001 | 12:16 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
i would think that there is something wrong with your emmissions stuff. if you don't have to comply with emmissions then take it off.
Andrew
InfernalVortex
04-20-2021 11:31 AM
Rocket-Doc
11-14-2015 02:08 PM
Cole Curtis
Theoretical and Street Racing
10-03-2015 12:26 AM
drumstixer
09-29-2015 03:02 PM
IROC ZELLER
09-29-2015 03:00 PM
Quick Reply: need help!!!diagnostic knowledge
