Running hot...HELP!
Running hot...HELP!
Ok...I just moved to Georgia.. Augusta to be specific...
At any rate...I dont know if its the humidity, the new K&N filter, or thermostat, or whatever, but the cars temp gauge is climbing right up to 220 and beyond.
For some reason, since the K&N went in, shes been running hotter...should i switch back to paper or something?
160/170 thermostat?
Advice is a good thing here...I cant afford to have the T/A croak.
-JT
86 Trans Am
305, A4, etc..
160/170 thermostat?
-JT
86 Trans Am
305, A4, etc..
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
an air filter generally wouldn't cause that to happen what are the symptoms are you overheating in traffic or on the highway?if it's on the highway check your air dam on t/a's they are crap i put on an iroc air dam makes a world of difference if not check to make sure the fans are coming on at 217 degrees and a last resort make sure the waterpump is operational.i'm assuming you have coolant in the radiator!!!!!!
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,1 5/8 headers,y-pipe,edelbrock base,hi flo cat,air foil,afpr,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ads strip chip,relocated iat sensor,tb bypass,hollowed maf,a/c delete(whole lotta room in there now)
14.10@97mph w/2.01 60'
siamesing the slp's and my fastchip eprom is on it's way
Shes running hot just about everywhere...highway, traffic, stopped, etc.
Quite simply, since the K&N was put in, its running hotter.
Water pump works fine.
Air damn is still ok for the most part....
The fans dont come on automatically...I had to wire a manual on/off switch into it til i can find whatever is broken thats supposed to turn em on.
KEep the ideas coming though, eh?
-Jason
-Jason
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
How old is your radiator?
My IROC ran warm since I bought it last year.
The fan ( aftermarket ) was wired to run all the time. The lower air dam is there and working. I swapped in a new water pump, but it still ran warm. It was also pinging quite a bit. around 200* according to the gauge. last week the car started to show signs of over heating.. I swapped in a new radiator, and a 160* stat. The car runs MUCH cooler now. Just barely cracks 120*. I am going to switch to a 180* stat and see how it runs.
The plenum used to get too hot to even touch on just a short 5 mile trip.... now even after an hour of driving it only gets warm. Also the pinging problem is gone
Member of The Connecticut F Body Association
1987 IROC 5.7 - 14.72 @ 92
1988 Formula
1986 Z28
1988 Formula
1986 Z28
You'll make it into closed loop at about 105, but there maybe other sensors affected by only a 120.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
1989 IROC-Z 5.7L
NOS 150HP kit
The coolng fan problem...the relays right above the battery, they go bad all the time.
Also, remove the radiator and check to see if theres a buildup of crap between the rad and the A/C condenser. That is also a common problem that is often overlooked.
Another thing you may want to do is gound out the wire going to the sensor on the pass. side cylinder head. It controls the fans. Thats where you may want to hook up a switch. One side to the wire, the other side to ground. The fans will then have full manual control while still having adequate power supply at all times.
Also change the thermo to a 160 or 180*....
Should solve all your problems....
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Mike L.
my car was running past 220. and then i thought i would put some radiator cleaner in, well 3 bottles later, it runs at 180, with a 180* stat. couldn't of asked for more.
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Car: 88 IROC
Engine: 5.7 RamJet
<font face="Verdana, Arial" size="2">Originally posted by ron rizzotti:
is your thermostat opening??
120* is way too low, the car wont even make it into closed loop mode.</font>
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
When I went to a 160° stat, my temp was right between the 100° & 220° mark, When I went to TPI, I kept the stock 190° stat without changing a thing to the gauge, and it READS 220°, but I know it is only at 190°, because my scan tool tells me so, and 1 fan should kick in at 222° with an 86-88 stock chip.
Car: 86 T/A
Engine: 5.0 TPI
Stock fan turn on temp on an 86 is 234°.
Try following this diagnostic:
http://www.gmtips.com/3rd-degree/
Enter Site
Choose Tips
Choose Car Overheating
Also be aware that the 86 most likely has a bugged stock PROM. Updated to the new PROM will solve many potential problems as well as lower your fan turn on temp. You will find the TSB about this in the tips section as well.
<FONT SIZE="2" COLOR="red">Red 86 T/A</FONT><FONT SIZE="2"> 5.0 TPI</FONT><FONT SIZE="1"> </FONT><FONT SIZE="2">(LB9/WS6)
~HyperTech Cap/Coil/Rotor/AFPR
~Derale Adjustable Fan Switch ~ 170° Stat
~Flow Matched Injectors ~ K & N Air Filter
~Ported Plenum ~ Pirelli 245/50/16
~SLP TB Airfoil
~All Else Stock</FONT>
<A HREF="http://www.gmtips.com/3rd-degree/"><FONT SIZE="1" FACE="MS Sans Serif"><IMG SRC="http://www.gmtips.com/3rd-degree/cg/3rd-logo.jpg" WIDTH="100" HEIGHT="80" ALIGN="BOTTOM" BORDER="0"></FONT></A>
[This message has been edited by MikeInAZ (edited July 13, 2001).]
Enter Site
Choose Tips
~SLP TB Airfoil
Torchta, welcome to the Hot 'Lanta. You now know why it has earned it's name. My car runs about the same but for a couple different reasons. I would suggest you flush the system and run some water wetter with a little less anti freeze. If you have problems doing this there are a bunch of Camaro guys here who will give you a hand. Check out my site....
Hank
87'IROC Z28
Hanks 87 IROC
[This message has been edited by Hank Brote (edited July 13, 2001).]
Hank
87'IROC Z28
Hanks 87 IROC
Fast355
12-02-2016 06:33 PM
eightsixseven
08-14-2015 03:09 PM
