witch cam shaft for my TPI
Old 01-19-2008, 11:52 AM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello
i looking for a camshaft for my chevrolet camaro 305 TPI (5 speed manual)
1988 !!
i want a little bit rough idle (i like the sound from rough idle)
so i see somatch cam shaft`s on the inernet (summit)
but i don`t no witch i must buy!
who can and will help me with my choise??
i have a stock engine whit only hedman headers and a accel super coil
and a flowmaster (no cat anymore)
please send me a private message who will help me
gr dennis
Old 01-19-2008, 12:24 PM
TGO - 10 Year Member
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Re: witch cam shaft for my TPI
crane 104227
or better yet the crane 104224. those will work ok
comp cams 08-502-8 is a great grind too
but you will need the heads worked over to handle the lift
Old 01-19-2008, 12:42 PM
Car: camaro iroc-z
hey thans for the fast answer!
but what you mean with
i have some aluminium stock heads on the motor!!
gr dennis
Old 01-19-2008, 12:48 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
will that 104224 grind have a rough idle in a 88 350 gta......
Old 01-19-2008, 03:49 PM
Adrians91Z28's Avatar
Car: 91 Camaro Z28 Convt.
Engine: 305 TPI (built)
Transmission: 5 spd
Axle/Gears: 3.08 posi
your "stock" heads will only handle about .460 lift (if i remeber correctly) ..
so you either have to get the heads machined / worked .. or you can go to summit and get some new performance heads as low as $250 each ..
Old 01-20-2008, 03:39 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
i have the crane cam in my 305....sounds great.
Old 01-20-2008, 10:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
rough? no...kinda far from it but depends on your definition of rough idle. to me a rough idle is a cc306 or similar cam which is a BIG cam
Old 01-20-2008, 11:04 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
Correct me if I'm wrong, but I believe the stock heads will support .480 lift. Check this out: http://www.compcams.com/technical/Ca...67_226-227.pdf
anything with 114 degrees LSA and around .480 LIFT would be great as long as it is hydraulic roller, considering you have an 88 block.
I would highly recommend the TPX262HR-14. It has .486/.480 lift, 210/218 duration on a 114 LSA which would really wake your motor up. If you click the link its about midway down under the designated TPI POWER EXTREME camshafts.
Old 01-21-2008, 12:10 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Daniel is right, it will handle .480. i have the comp 08-302-8 in my 305, .08 shave on the head and a .20 gasket and im at about 10.41 comp.480/480,210/220,112
i would sugguest the 08-300-8, it reqs no tuning and will do PLENTY for your 305. id drop in new springs while im at it, 981-16 is what it recommends. this cam is 450/480,206/210,112. dropped this in my friend 88 GTA 350 car and it worked superb.
Old 01-21-2008, 08:57 AM
Transmission: 5 spd
man .. i wanted to get the 08-302-8 for my 305 that i just rebuilt ... but summit said it was discontinued or some b/s .. instead i got the 08-501-8 which is what comp recomended for my setup ..
but then again .. im runnig summit racing vortec heads (up to .520 lift / bigger valves) .. edelbrock vortec tpi intake manifold .. hooker 2055 headers / y pipe ... taylor 8mm wires .. etc ..
im almost done puttin it all back together ..might start it today .. so ill let yall how my cam is ..
adrian
Old 01-21-2008, 01:52 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
and if u put 1.6 rocker arms on there then it makes the lift bigger too
Old 01-21-2008, 04:50 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Adrians91Z28, lets just say i know for a fact and first hand that cam isnt discontinued.
Dennis, if you dont have knowledge of how to tune or have access to someone that can and is good at tuning id go with the 08-300-8. no tuning reqd, good street manners and that is formost as too much cam cam make for a bear of a car and thats no good for a daily driver. also, with a EFI system the "chop" will sound much diff than a carbed car. EFI dosent do well (on the avg) with a LSA lower than 112.
Old 01-21-2008, 06:21 PM
Transmission: 5 spd
yea .. thats what i figured .. its just i bought a pos edelbrock cam at summit before i did ANY research on building 305's .. haha .. came to find out it was a smaller cam than stock ..
so i went to exchange it and they told me some crap about they cant get it from comp or something ...
but i got the comp cams 08-501-8 .. i just started the motor for the first time 3 minutes ago .... and all i gotta say is HOLY crap .. its sounds amazing and the throttle response was crazy fast .. havent driven it .. just started it for a couple minutes ..
ill let yall know how it goes tommorow when i drive it ..
adrian
Old 01-21-2008, 07:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
501 is a small cam, not much bigger than stock L98 cams, just has a good deal more lift. i'd expect that cam to peak at 5400ish rpms. I would go with the 502 over that.
Old 01-21-2008, 08:26 PM
Transmission: 5 spd
yea .. its a little bigger than the stock cam ..
but i got a 305 .. not a 350 .. and i wanted more low to mid range torque for that "kick you in the seat" feel .. without over camming it and ruining my gas mileage ..
just depends what you want out of a cam .. a daily driver .. or a mean drag racer ..
i called all of the cam company's and got there recomendations and did some more research and from there chose the best out of those
adrian
Old 01-22-2008, 10:11 AM
Car: camaro iroc-z
okey and what do you say about this cam
CRN-104225 Camshaft, Hydraulic Roller Tappet, Advertised Duration 264/270, Lift .438/.452,
i saw these by summit for $285,- USD
can i use these for my 305,heddman headers,stock aluminium heads (LB9)
gr dennis
Old 01-22-2008, 01:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yes you can use that cam for a stock computer car with no tuning and it will run fine. that cam is no bigger than a stock L98 cam, but maybe abit more aggressive ramps. I like to call that a cheater cam, basically a more modern L98 cam
i think you could go one step up and still be fine yet make good power over that cam
Old 01-22-2008, 03:05 PM
Car: camaro iroc-z
is there any better cam for me?
do you now any cam?
i want the maximum on a stock computer,good torq and good HP
gr dennis
Orr89RocZ vbmenu_register("postmenu_3609925", true); Do you have msn messenger?
my msn adress is
w.jung@chello.nl
Old 01-22-2008, 03:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
no sorry i dont have msn.
I think either of those crane cams will work just fine on the stock computer. the 224 cam which is slightly larger will need a adjustable fuel pressure regulator to get the fueling more dialed in but even stock cars can benefit from tuning. You can adjust timing tables to get every bit of power out of it.
comps 08-501-8 is a good one too, but you will have to add shims/offset locks to handle that lift on stock heads.
oh and to add, Lb9 305's and camaro L98's had iron heads stock.
Old 01-22-2008, 03:48 PM
Car: camaro iroc-z
hmmz okey than i buy the crane 104225 by summit!
and i`m sure that i have aluminium heads!!
are you sure that they are not stock??!!??!!
i have a iroc-z 305 tpi 1988
Old 01-22-2008, 03:54 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
they should be iron....i'd check the casting number on the head to see whats goin on there. before you buy anything, check to see if you really have a 305 in there and see what heads you have
Old 01-22-2008, 03:58 PM
Car: camaro iroc-z
okey i will check them tomorow and let you know wich nr stands on the heads!
i know that my vin code have a letter F and i have check the vin code before on www.camarosource.com and they say its a 305!
gr dennis
Old 01-22-2008, 04:26 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
http://www.youtube.com/watch?v=eX0LbUwSIfk
Old 01-23-2008, 10:20 AM
Car: camaro iroc-z
hmmz the sound likes good!!!
thats what i`m looking for!
dennis
Old 01-23-2008, 02:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i think the crane cam 224 will get that kinda of lope. comp cams 501-502 cam will definately get that lope in a 305.
Old 01-23-2008, 03:00 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
dennis
Old 01-23-2008, 03:11 PM
Car: camaro iroc-z
hello
here are my pictures from my heads
and they are aluminium
Old 01-23-2008, 03:29 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
88-up 10088113 350 1.94 1.5 58cc angle plug, alum., Vette, raised (.100") D-port exhaust
Someone changed your heads...... Cool.
Old 01-23-2008, 03:45 PM
Car: camaro iroc-z
yes i know i have seen it on www.mortec.com
or i have a 5.7 l engine
i`ll check this tomorow!
are these heads from a corvette??
gr dennis
Old 01-23-2008, 06:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
oh wow, good deal man those are pretty decent heads! Corvette 113's are popular and are a good base to build on
Now you must find out block casting numbers to verify if you have a 305 or a 350. check that pad that is in front of the passenger side cylinder head, above the timing chain. it will have two number codes on it. give me those numbers and i'll tell you what you have
cam choice will depend on that.
Old 01-23-2008, 06:13 PM
Transmission: 5 spd
hey .. orr89RocZ
i just got my 91 305 runnin with the 08-501-8 cam ..
it runs / idles fine .. but drives like crap .. what timing / fuel pressure do i need to start with ..
ive been messing with it .. but i noticed some liquid splattering out the exhuast pipe onto the ground .. im gussing its fuel .. but i dont know if its unburnt fuel or my rockers arent adjusted right and a cylinder isnt sealing right ..
neways .. what do you recommend for a good starting point on timing / fuel pressure .. i got an adjustable regulator .. but i gotta run and get a gauge
thanks ..
Old 01-23-2008, 06:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i'll send you a pm
Old 01-23-2008, 06:40 PM
Transmission: 5 spd
thanks alot .. i got somewhere to go from now .. might try it in a sec .. sent you another pm with a few questions before i try it ..
adrian
Old 01-24-2008, 01:44 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
why not just pick up a used lt1 cam?
i am looking for a roller cam for my 305 i have ported the upper plenum and have a afpr but that is it. i will be using stock computer i want a cam that will work with it no problems and get good gas mileage. the car ran 15.4's with everything stock, i now have a five speed instead of the auto with stock stall and a 3.45 rear gear instead of the 2.73, i would like to hit mid-14's with this 305 but keep good gas mileage. help me pick a cam please.
Old 01-24-2008, 09:43 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
LT1 cam or pretty much any of the above mentioned cams will push a 305 5sp into the 14's. i know many that went high 14's stock
Old 01-24-2008, 04:10 PM
Car: 88 IROC
i think i am going to go with the lt1 cam or possibly the lt4(not hotcam) cam. i would like to run 1.6 rockers so can i just upgrade the springs to compensate or do i need to do headwork for the added lift? also this motor was out of a 305 tpi auto from 88. does it have the "big cam" or was that just the 5-speed cars? also i have the original 305 auto computer and chip but i am running a 5-speed can i just get a 305 5-speed chip and be ok or is there any kind of wires that need to run to the 5-speed for the computer? am pretty sure my 700r4 had a connector hooked up to it, idk if the 5-speed requires anything
Old 01-24-2008, 08:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
88 could possibly have the L98 cam but more than likely it has the smaller cam. i think 90+ years all had the bigger cam.
depends on what LT1 cam you get, lifts are different for various years. with 1.6 rockers on LT1 cams, you'll be cutting it close on max lift for the heads. Lt4 cam i think is rated with 1.6 rockers but you'll have to look it up to be sure.
you proby can use the 305 5sp chip and be just fine. get a 88 5spd 305 chip.
Old 01-25-2008, 10:53 AM
Car: camaro iroc-z
heey good news for me!!
i have check the engine codes and is it as follow nr`s : 14093638
and i have already see that is a 5,7 L
now my question!
witch engine is this?corvette?
how much HP original?and the torq?
and witch cam sahft must i take now??
thanks Dennis
Old 01-25-2008, 02:30 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
lucky dog you! that is a corvette motor from 87-91. If its a MAF car then its a 87-89. surprised it has a 5 spd too. they generaly dont hold up well to 350's torque
depending on the year, hp is rated at 240-250 and torque 340-350lbft. In reality its more like 250-260 on motor cuz those will put down 220whp stock, some abit closer to 230. Thats healthy
Now you need to reconsider the cam... gotta step up a few steps. comp cams 502 is a nice choice now.
Old 01-25-2008, 03:13 PM
Car: camaro iroc-z
hey Orr89RocZ
thanks,you help me a lot!
can i buy the comp cams 502 whitout chancing the computer???
and what will i win (in torq and HP) wen i buy the 502 comp cam?
i see some difrence 502 cams on the site from summit!
witch won must i buy??
gr dennis
and do you now if i need the roller cam or flat tapped?
Old 01-25-2008, 03:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
that block with that number should be a roller block. Just buy looking at the pics, it appears to have roller lifters.
teh comp 502 cam, 08-502-8 is 218/224 with .495/.503 lift. You will need new springs for it. Can reuse stock retainers more than likely if you stick with a stock style spring like the comp 981's. You will need 7degree +.050 locks and .060" of shims. 7 degree locks can be hard to find, so then you will need 10 degree retainers and the offset 10 degree locks and then ofcourse teh shims. This is to handle the lift of that cam.
Part numbers can be something like this: offset locks 10 degree CCA-614-16
retainers 10 degree comp cams cca-750-16
springs, comp cams cca-981-16
shims comp cams CCA-4753 just use the .060's
that will give you the spring pressure, and ability to handle that cam lift without machining the heads.
stock MAF computer will handle it, but you should look into a tune. Atleast get a fuel pressure regulator and also play with base timing. Try 10 degrees and 46psi fuel. Is a good starting point.
Old 01-27-2008, 03:16 PM
  #42
Car: camaro iroc-z
hey
i have order some parts by summit racing
i have buy a cam shaft from crane comp cam
so i think the 08-502-8 what you said Orr89RocZ is to much for me!
i think my computer can`t handle it!!and it`s to rough for street driving!
but thanks for your help!!
gr dennis
Old 02-07-2008, 04:55 PM
  #43
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
what would new heads like those be worth?
i gotta rebuild my engine and would like a cheap set of aluminums.
what gains would i see over stock L98 heads
Old 02-07-2008, 05:15 PM
  #44
Car: camaro iroc-z
hey you can buy some corvette heads!
but i don`t now off there are cheap!!
Old 02-07-2008, 09:26 PM
  #45
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
the intake ports may flow a few cfm more but its not much to see alot of gains from that, but every bit helps. The exhaust ports tho flow alot better than stock irons. they will help make alittle power thru better scavenging of the cylinder. Getting more out wll help get some in.
other gain is they are lightweight and have 58cc chambers to give you alot more compression. But since aluminum dissipates heat more rapidly, the extra compression is needed so the gains are offset
gta90
09-15-2015 04:00 PM
theurge
08-21-2015 12:46 PM
Sanjay
08-12-2015 03:41 PM
MENINBLK
08-05-2015 11:58 PM
Quick Reply: witch cam shaft for my TPI
