comp cam XFI 280
Old 12-27-2007 | 04:29 PM
BadAz_Iroc's Avatar
comp cam XFI 280
I would like to know has anyone use the comp cam XFI 280, the one with the .576 lift RPM rang from 2000 to 6000, if so tell me what you think of it vs the XFI 268 with the .570 lift RPM range 1800 - 5800 i want to use one of these cams but undesided. 350 bored .030, HSR, 700R4
Old 12-27-2007 | 06:01 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Re: comp cam XFI 280
I'm running a XFI 292 and like it, but the power is all up high so yuor gunna need a stall and gears.
For a daily driver I'd suggest the 268 over the 280, give you abit more low rpm power for cruising around town
Old 12-27-2007 | 11:45 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its a big cam for a 350, so you better have good heads and a higher stall converter. Dont forget the custom chip tuning.
Old 12-29-2007 | 11:30 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have the xfi280 cam, although it is a flat tappet.
The power is up top for sure. But I have a 3200 stall and 3.73 gears.
When I have the engine below the sweet spot, once it hits 4500, it's awesome!
Make sure you have a good intake for that cam, it wouldn't work on a tpi.
I had a hard time deciding between the 268 and the 280 cam. On desktop dyno, the difference was about 15hp but the 280 cam made the power 500rpm higher, same with the tq, higher but it was 500rpm higher.
Hope that helps!
Old 01-01-2008 | 12:40 PM
Guest
Guest
Posts: n/a
It works on a TPI.
But, I'd go with the 268 for a daily driver with a 350.
Old 01-02-2008 | 11:38 AM
BadAz_Iroc's Avatar
Thanks guys, i knew someone here was running those cams, i am going with the 268 for daily driver.
F.I. 57 Belair
08-23-2021 02:09 AM
Jorlain
10-08-2015 02:57 AM
customblackbird
10-01-2015 05:30 PM
sandman92084
09-12-2015 11:27 PM
Strick1
09-04-2015 08:11 AM
