How to Bypass the knock sensor?
Car: Red Rooster
Transmission: M5
Does anybody know how?
Please let me know.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers 1 1/2, Hooker Y-Pipe 2 1/2, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, MAF Screens/Fins removed, K&N, Gutted Air Boxes, AFPR @45 psi, Ram Air, Throttle Body By-pass, Bumped Timing @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac rear Shocks.
Please let me know.
Don't do it, you might lose a piston.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Past Thirdgen:
Car: Death Mobile
Engine: 666 c.i.
The best thing to do is control it properly within the eprom. I agree with Kyle and do not beleive you should disable it, you are asking for more problems that its worth.
Car: 04 GTO
Transmission: M12 T56
Boo you guys, really, BOOOOO!
Without a scanner and the ability to see what is really going on, bypassing the KS can be a good way to eliminate knock, whether false or true from your tuning equation.
Bypassing is gravy...3.9K ohm resistor to ground in place of the KS.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
...ed
Pwebbz28 (04-24-2020)
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I agree with Ed. Disconnect it. In my old TurboCoupe, we use to do this all the time. Even with 20psi of boost, just run real good fuel. Everything will stay together.
Joshua Johnston
1991 Z-28
Flowmaster
K&N
305 / 5spd. (Temporary)
Joshua Johnston
1991 Z-28
Flowmaster
K&N
Car: 04 GTO
<font face="Verdana, Arial" size="2">Originally posted by WHITE87GTA:
what would happen if you just diconected knock sensor and did not put in the 3.9k resistor? do you need this resistor?</font>
Also, i wanted to add to my earlier post, saying you really shouldn't do this as a long term fix. Use it as a tuning aid so you can hear knock, rather than have the computer take timing out before you even know you're pinging. Or if you find out you run a lot stronger with it bypassed you know you have an issue with false knock stealing your timing.
...ed
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
supposedly the factory program takes out 2-4 degrees of timing when the car shifts from 1st to 2nd on an auto i read an article a while back it said to splice a 3ohm resistor into the circuit and hook it back up normal
1 Post
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
I drove my '86 around when I first got it and never had a problem. After putting about 4k mile on it, I noticed it disconnected, and plugged it back in. Never threw a code. Just make sure you run cool, set the timing before and run 93+ octane only. make sure there's no chance to detonate. Then look into disconnecting it...but then, you wouldn't need to, so it would be better to leave it in as a safety measure...I'd just do the prom work.
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I've heard that disconnecting the sensor without installing the resistor will put the ECM in limp home mode when the coolant temp goes above a certain temperature...if that's true, then I would at least put the resistor in to "trick" the ECM. Can anyone else verify this?
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
1 Post
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by DANIELEK:
Please let me know.
</font>
Please let me know.
</font>
Parameters for setting the error code vary some calibration to calibration. There is always a min coolant temp setting.
Some programs run a K/S test when you first turn the key on, and then again at over 3/4 throttle.
Some codes, won't allow Power enrichment if the system fails the K/S test.
If you want to disable it correctly, you need to read up on chip burning.
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Hey Glenn, I think you need to pull your weight around here. I mean over 6000 posts is really not going to cut it. ROFL j/k......
1987 GTA L98 MD8 GH3
355 '97 Vortec 4-bolt block, TRW(suck) forged pistons 10:1 CR, TFS 23*, LT4 Hot Cam, Ported plenum and intake, SLP Siam Runners, Edelbrock TES, gutted Cat, Flowmaster, Home-made cold air system w/ K+N cone and AFPR, TB bypass, AirFoil, !AIR, !A/C, 2300 stall.
"Stop Lights timed for 35Mph are also timed for 140Mph"
1 Post
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I woldn't reccomend removing it either, unless you know how to recognize detonation (including when you can't hear it).
You could just desensitize it instead of completely removing it.
Remove it,
clean the theads thoroughly,
apply several wraps of teflon tape to the threads,
Reinstall with just enough torque to seal it from leaking coolant.
Plug the connector back in and you're done
You'll have less protection but still some, and you won't have to worry about the ECM getting ticked off at you.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
- 355 cid
- AFR heads
- Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
- modified SLP runners
- TRW forged pistons/ceramic coated
- fully balanced
- Edelbrock headers/ceramic coated
- SLP cat-back
- Paxton supercharger
- Nitrous Express nitrous oxide
