tpi problem?
Old 12-15-2007 | 08:03 PM
wes's 87 gta's Avatar
Car: 1987 gta
Transmission: 5 speed
Axle/Gears: 9 bolt 3:45
tpi problem?
l have recently swaped my 305 for a 350 tpi in my gta, since it is a 5 speed car with tpi it should have work well. However it is only running on 4 clys. the right side, the left side are pulsing and there is spark. Could it be the injectors, or maybe l am off a tooth on the dist.? please can some one give me any ideas!
Old 12-16-2007 | 01:01 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: tpi problem?
Check your fuses. There are two, one for each bank of 4 injectors. Also check your injector wires and make sure you dont have a short or an open.
Grant2k
07-10-2018 04:01 PM
Infested
05-22-2018 11:56 PM
jbd1969
08-17-2015 07:06 PM
gta power
08-13-2015 06:15 AM
Sanjay
08-12-2015 03:41 PM
Quick Reply: tpi problem?
