Dual fan setup with one fan
I just set up a 87 TPI system form a 30 GTA that had dual fans. I have only one and am wonding which clip do i use, is the a primary and secondary? or do i just splice them to both go onto the same fan? I am thinking that woudl overp[ower the fan when the both feed power. Thanks for reding , any replies are greatly appreciated.
if you splice them you will probably short them out.... the drivers side fan is the main fan. Just hook up this one... i think the clips are the same so if you don't know which one is for the drivers side you may have to hook one up get it up to temp by idling and see if the fan kicks in.. if the fan doesnt kick in its the other clip...
hope this helps
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3.5 " Cat Back, MSD Ignition, K&N Cold Air kit
hope this helps
Mike
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
