K&N Air Filter for TPI
Car: 89 IROC Z28
Transmission: 700R
Does K&N make a nice cone filter that will fit right over the throttle body of a TPI?
If so could you give me the part number. I tried searching some web sites that sell K&N but they only have search engines for year and model.
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: K&N Air Filter for TPI
I think the number is something like RC5000 or so. I've bought a few from summit and jegs.
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Go to summitracing.com
search for "k&n TPI"
There are 6 results that come back.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
If your car has MAF then you can't bypass it. One of your options if you have MAF is to swap the ECM which is a 1227765 to a 1227730 ECM and the Eprom to a AUJP that controls Speed Density and MAP. You might have to get a Moates adapter and reprogram your ECM to over-ride the Vats and then change your VE's and repinning your computer is only benificial if you are doing major engine mods like I have because your MAF ecm won't handle them. Other than that. Keep your ECM and MAF and just get the 2 K&N filters for your air ducts.
1992 Trans Am
05-10-2023 07:19 PM
