Belt length when removing smog pump.
I need to know how much shorter to get the serpentine belt after I remove the smog pump. Or a part# for the belt would work. This is a serpentine setup not the hybrid.
1989 S10 Blazer 355/700R4
I used a 93.5", but i have underdrive pulleys. Doug
Central Indiana Camaro Club member since Oct. 2000
1991 Z28 - 51,000 miles.
Dyno Results: 226.4 Max Hp; 310.4 Max Torque (ft-lbs)
All power options leather. 350 TPI:
K&N; Airfoil; Custom 'Ram-Air'; Slp Runners;Poweraid TB spacer;
Fastchip;
SLP Headers; Borla Catback 50% open; Dual factory Cats;
March underdrive pulleys;
Accel Extreme 9000 wires, Accel coil; Hypertech rotor & cap; NGK platinum plugs;
Manual fan switch;
TB coolant bypass; smog pump delete
Spohn subframe connectors (black powder coat);
Pirelli P7000 Z245/50/R16 all season tires;
Energy suspention motor mounts
S Cobra Radar Detector; Z28 SS Floormats;
Technalon IV car cover (now on my dad'a 2000 Berger SS).
Fastchip;
Manual fan switch;
just get a belt for a 1le car that doesnt have air obviously , and it will work fine
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,TB coolant bypass ,polyurethane tranny and torque arm mounts, k&n oil filter,synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You should try reading the tech articles, it's in there.
OK, here's the link.
https://www.thirdgen.org/newdesign/t...rpentine.shtml
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
86 Camaro Sport
My Camaro Project
backtothe80s
09-05-2015 12:39 AM
mustangdmurder
08-21-2015 07:17 PM
