TPI Intake Capability with Various Chevy Heads
1 Post
Car: 1992 Arctic White Z28 Convertible
Engine: LB9 305 cid TPI
Transmission: 4L60
Axle/Gears: B-W 7.75" 3.73
*I'm looking for a source that identifies the compatibility of 350cid TPI intakes with the various 350 heads available for late-model Chevy V8's. It's my understanding that TPI set-up's aren't fully compatible with all 350 heads.
Reason: I possess a TPI intake from an '89 Corvette and am currently investigating a TPI-equipped crate motor set-up for a '90 IROC-Z.
The Corvette TPI intake has the perimeter-bolt-head intake pattern, with all 45º holes. The 85-86 F-body intake is the same. The 87+ TPI intake has the centerbolt-head intake pattern, with the middle 4 bolt holes being 72º. Just match up the head angles with the intake angles and you'll be fine.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
1992rs/ss
05-19-2020 07:02 PM
Sanjay
08-12-2015 03:41 PM
