attn. GM Tech
Car: 86 Z28
attn. GM Tech
I have a prom that is suppost to be from an 88 350 TPI. It has the no. 16035006 8611 on it. Is there any way you can verify the part no.?
Car: Take
Engine: Your
Transmission: Pick
The 16035006 is not a valid part number, it doesn't even supercede to anything, so I can't help you there. I would go to the PROM board, and see if anybody knows anything about the 8611.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Car: Take
Engine: Your
Transmission: Pick
No, but I bet if you take that last number you just gave to the PROM board, they could help. I am only familiar w/ Speed Density .BIN files (AUJP 1350 and such), and without a valid part number, the PROM board is your best bet. Good luck.
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
South East Thirdgen
GM Master Tech
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
'97 Bonneville SSE
Car: Death Mobile
Engine: 666 c.i.
If it is an AUM, then it is for a 305 MAF car. I cannot find a cross-reference for an AMU for the known ECMs that I've been able to find from GM. This is not saying that an AMU does not exist, I just can't find it for the common ECMs used by GM.
Pac J
05-17-2020 10:44 AM
