K&N Cone Air Filters - Worth it?? 600 cfm or 1000 cfm??
I am looking into a K&N cone air filter that mounts right onto the throttle body. I have a stock TPI intake on a 355 motor, but I do have a hot cam and headers with a high flow exhaust. Do you guys like it? How does it compare to the home-made ram air kits? Why would anyone buy the 600 cfm one? Wouldn't it be best for every motor to force in as much air as possible? Thanks for the help.
Car: 1988 Trans Am GTA
Engine: 383
Mine is a mass air car and I have a cone K&N where my stock air box used to be, so how can I not do it???
Veiw MY CAR at:
http://www.members.tripod.com/~btessier
88 GTA
L98 350
700R4
3:27 axle
MODS,
Edelbrock TES headers, 2.5" straight pipe, Flowmaster 80 series, K&N filter, Accel 8.8mm wires, Bosch Platinum plugs, Wells cap and rotor button, Wells ignition module, MAF screens removed, Hypertech TB air foil, Thermomaster stage II chip, 180* Powerstat, Hypertech cool fan switch, B&M shift kit, B&M power clutch pack, B&M servo, GM fuel filter.
Veiw MY CAR at:
88 GTA
L98 350
700R4
3:27 axle
MODS,
You cannot use the 1000cfm. It is much too large; you will notice that in most descriptions of the 1000cfm, it says that it is for aftermarket systems. It will not fit a stock setup, and does not have clearence since the t-stat hose is in the way. Trust me, I tried it and had to send it back for the 600cfm.
91 black Z28 305 TPI
Plans for 383...
Jet-coated TES headers, Flowmaster cat-back,
SLP cam (206/212@.050), Cloyes double roller timing chain, TPIS shocks/struts, TPIS STB, adj. fuel press. regulator (47psi), 170 stat, B&M shift kit, BMR 1.5" springs, Ed Wright custom chip, gutted air box, K&N cone filter, Mac Ewen white face overlays
3rdgeners in Europe: CLICK BELOW!
www.fbodyeurope.com
Plans for 383...
www.fbodyeurope.com
1992 Trans Am
05-10-2023 07:19 PM
Brinkkl2000
08-04-2018 08:29 AM
