Swap to TPI from 4BBrl Carb
Old 11-15-2007 | 11:58 PM
Staten Island S's Avatar
Car: Camaro, Monte,
I have an 86 Z28 with the Rochester 4bbrl. I recently bought an 86 Iroc TPI with 82k original miles. Other than some oil leaking from a loose intake (I think) when hot, the engine really ran well. It is the 305 TPI and everything looks to be original and unmolested. As a matter of fact I have a folder with every receipt for everything done to this car. I'm looking to pull the TPI out and pop it into my z28. I understand the computer will have to be swapped and I assume another fuel line for return will have to be installed. Other than that how practical is a swap like this for the novice backyard mechanic?
Old 11-16-2007 | 10:52 AM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
Re: Swap to TPI from 4BBrl Carb
Did the same thing on mine 6 yrs ago. Best thing in my opinion is to get the computer, and maybe look into getting an aftermarket wiring harness for simplicity. Yes the extra fuel line will have to be ran, however taking the tank, fuel lines, fuel pump, and the motor out at once which is what I did, you should have no problems. Everything should bolt right up.
Old 11-16-2007 | 09:27 PM
Car: Camaro, Monte,
Do you mean taking the tank and lines from the donor car? Can fuel lines & tank be reused on another car without bending/busting them all up?
Old 11-17-2007 | 07:32 PM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
your best bet would be to PB blast everything down that you need and slowly take everything off, I would just get all new rubber hosing for the fuel lines. No sense in taken off the lines and having them leak down the road a few weeks later. Its not that expensive to get hoses. check for rust too while your under there.
Old 11-18-2007 | 03:01 AM
Axle/Gears: 373s
I reused the donor cars fuel lines. I took it out carefully and reinstalled it carefully. No problems. Before I knew wether or not it would work I took the tank lines and computer and ran the motor on the engine stand.
Old 11-18-2007 | 09:20 AM
Car: Camaro, Monte,
How do you even begin to remove a fuel tank?
Old 11-18-2007 | 01:22 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You have to drop the rear end, first.
Old 11-18-2007 | 01:59 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Take a trip over to www.chevythunder.com.
He has a lot of good stuff on the TPI upgrade.
I've used his thread and everything I've learned here and have done 5 different installs in non TPI stuff.
Ron
midge54
12-27-2019 05:14 PM
midge54
01-29-2017 08:00 PM
gta90
09-15-2015 05:00 PM
86IROC112
08-17-2015 03:00 PM
Sanjay
08-12-2015 04:41 PM
