Lowest my TPS will go is 0.94 volts? VADER?
I went out and checked out my TPS and the lowest the value would go was 0.94V. It is going above 4 volts so I thinK it is just bad at idle if that is possible? I don't know much about the TPS. I ordered a new one anyway just to be sure. It did bring my Idle down when I adjusted it but it is still high.
Vader....I did check the bore and everything is tight and i don't see anything that looks like it is binding.....It seems to be running rich when I am driving at low speed.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
91 Z28 Camaro
305 TPI
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
when you put a new tps on it wright us and tell us how it is doing.
84 Z28
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
t-56 trans
9" ME rearend
84 Z28
406
accel supper ram
afr heads
t-56 trans
9" ME rearend
Car: 1985 Trans Am
I think you have the non adjustable TPS.... I may be wrong, I'm not sure. If it is non adjustable, the ECM sees the lowest value and uses that as the baseline, IIRC.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Kevin Irving
PW,
Kevin nailed it. You have a non-adjustable TPS (1990 and newer) and accordign to my data, anything below 1.0VDC at idle position is acceptable, but you are pretty close. The ECM will "learn" the base position when the ignition is turned on, and calculate the throttle position from there. A new TPS might read a little differently, but may not fix the problem. Before replacing the TPS, you might try to loosen the mounting screws and take up all of the slack in the mounting holes to lower the voltage a bit.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Later,
Vader
"What a Day..."
I did that yesterday and when i came out of the parking lot at work I almost put it in the ditch!! It has been flooding I guess. The car has way more power!!! I have another one on order that I will replace the old one with. I want to make extra sure because adjusting the slack made the car idle fine again. It is probably the original and it has 200,000KM on it. It is probably due for break down!!
So will the new TPS I get be adjustable or is the 91 style self adjusting like you were talking about? Everyone always talks about adjusting them and the book doesn't even mention anything about a non adjustable one? Thanks for your help guys!!! I would be up the creek without a paddle if it wasn't for this board!
91 Z28 Camaro
305 TPI
91 Z28 Camaro
305 TPI
so if you have a 90 or newer car you cant adjust the tps. And the way to make it better is to adjust the slack. But what slack are you adjusting. Somone try to explain this to me Thanks
91 formula
305 tpi
borla exhaust
white face gauges
home made cold air
tpis airfoil
91 formula
305 tpi
borla exhaust
white face gauges
home made cold air
tpis airfoil
The holes in the TPS for the screws are a little bigger than the screws themselves. It allows you to adjust it a slight bit. By pushing mine down as much as possible I fixed the idle problem. I think the TPS is starting to go bad though so I am going down right now to pick up the new one.
Side Note: Someone might want to put this info in the tech artical on the board. If it wasn't for u guys I wouldn't knoow anything at all.
91 Z28 Camaro
305 TPI
91 Z28 Camaro
305 TPI
Car: 1985 Trans Am
If you have any room in the holes from side to side you should push it forward too.... that will bring down your idle voltage a bit, maybe just enough to make you comfortable.
