OPINION ON CAM FOR 85 TPI 305 with MAF
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
I have a 1985 IROC-Z 305 tpi and was wondering which CAM would be best to be installed with the stock heads. Recently, I've been looking into the COMP XR276HR--would this cam be compatible with the stock heads and chip? The unit has MAF. Any opinions?
Re: OPINION ON CAM FOR 85 TPI 305 with MAF
I was just reading somewhere on here I think that a stock LT1 cam could be good for like 25HP with stock heads and a tune. You have to grind off the optispark thing though.
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
That comp will need head work and tuning. Stock heads go computer controlled XE256 and get new valvesprings. Anything bigger is really a waste with the stock heads. LT1 wont work-it must be a flat tappet cam since 85 wasnt roller yet. This is assuming you have the stock motor/block.
85 is actually one of the bigger cams for a 305. I just put 1.6 roller tips on mine. Nice little gain.
Car: 85 IROC Z
I have read to stay under 210deg at .050 on the intake side to work with the stock computer. I just ordered the Lunati Voodoo 250 cam for my 85 TPI 305. My car is a daily driver, so I am keeping my computer stock.
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
That Lunati cam good for my 86 peanut cammed 305 tpi? Or should I stick with my first choice of the Summit racing tpi cam/lifter/spring combo?
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
http://store.summitracing.com/partde...2&autoview=sku
that should work great for your 85. the vortec swap would be another great idea for your 305
get some comp #981 springs. they'll work with your stock heads no problem.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
Could someone recommend a great cam for the 305 TPI roller engine? I have ported and polished stock heads, mildly ported plenum, with everything port matched. TES headers, high flow cat, flowmaster, descreened and de-finned MAF, MSD, T5, 3.42 borg rear.
Fast355
12-02-2016 06:33 PM
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
