Need help with cam part number
1 Post
Car: 1991 Z28 vert, 1988 GTA
Engine: 305 TPI, 305 Carb-finally runs!
Transmission: TH-700R4/BW WC T-5
Axle/Gears: 3.73 posi 4th gen 10-bolt/BW 9 bolt
My buddy gave me an LT1 camshaft that I am thinking about putting in a 91 305 TPI. I searched and searched and could not find any specs on the part number on the cam. This is all i could find:
GMPT.BC.15...705
Anyone have any clues as to what the specs are on this thing? Geez, heaven forbid GM just use a regular, easy to read and find part number!
Thanks in advance for any and all help!
Kevin
GMPT.BC.15...705
Kevin
Received 1,843 Likes
Re: Need help with cam part number
Google it.
Type in "LT1", "cam", and "705".
Isn't technology wonderful?
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
The Part # for the LT1 Cam with the 705 Grind # is GM-12551705. 1994-1996 F-body 350 LT1. The Spec's are.. 439/.447 Lift with 1.5:1 rockers. 209/217 degrees Duration at 0.50 Lift. Lobe Seperation:117. Hope this helps.
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
im bidding on that same cam on e-bay right now.
1992 Trans Am
05-10-2023 07:19 PM
IrocZ'85
08-17-2015 06:24 PM
TA8487
08-16-2015 12:21 PM
