are these options just plain bread and butter?
i decoded RPO's today and found following items as standard? are those normal options for GTA?
B2L : PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
GW6 : AXLE REAR, 3.27 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
JG1 : SHAFT, PROP, ALUMINUM
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
WS6 : PERFORMANCE PACKAGE, SPECIAL
Pontiac,
Welcome aboard!
Those options were not "standard", if that's what you are asking. They are desireable options and can be found on most of the better 'F' cars. The aluminum drive shaft and spare wheel are typically found on the 1LE cars that were factory designed for club and road racing. The FE@ and WS^ shuold also have some related options, like 6ZX, 8NB, and J65. Your car is one of the better models produced, and was intended for performance handling instead of smooth ride. What year is the car?
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Welcome aboard!
Later,
Vader
thanks Vader i already feel like home here LOL
the car is model 1989. first i thought that overdrive is not working since engine screams at 2000rpm on highway
someone has picked lot of options i guess, too bad he(or she) didn't take CD option.
this site will give you a lot of info on GTAs, definatley check it out http://gtasourcepage.com/
gixxer92
05-18-2017 11:20 AM
