most hp under 100$ ?
i recently got 89´GTA with 350. it's so damn slow as you might know so i'd like to make some mods and pay those new hp's virtually nothing
cheap ones:
- gutted cat?
- gutted airbox?
- TPI porting?
- raising fuel pressure by placing coins inside the FPR?
- MAT relocation?
- playing with timing (gas here is at least 95 octane)?
expensive ones:
- TPI airfoil?
- K&N (i think it's a crap compared to its high price)?
- underdrive pulleys(maybe the crank one only)?
- single 2.5" free flow muffler?
do i have any changes to run low 14's without changing cam, heads or headers?
what other mods you'd like to suggest?
If you are looking to do cheap mods, do all the free mods you can. Bypass the TB coolant, remove the smog pump if u have no emission testing where u live and run the shorter belt, purchase a coil, and get the MSD box later, or some sort of ignition system. and place your timing at around 10 degrees, that'll make ur car seem lighter...U can also remove your front sway bar for better weight transfer....Do that only at your OWN risk....Makes the car a bit shaky...but I'm use to it... =)
Anyone else know of anything?? I would look under the "tech articles" as well my friend!
Zach
Mods: Headers/flowmaster, K&N, 2k Stall, Custom shiftkit, 100hp Compucar N20 kit. Nitto 555R Drag Radials, MSD 6A, MSD Blaster Coil, No smog Pump and air foil.
Best e/t: 12.8@107
Best motor e/t: 13.59@102.7
Zach
Best e/t: 12.8@107
thanks!
i'd like to do only mods which really help. if someone have list of mods how to run 14's, that would be tremendeous help.
GTA fat*ss weight no less than 3800lbs and with driver 4000+lbs i bet i need at least 30hp more?
Car: 1991 GTA Convertible
There is an article in Pontiac Performance magazine that takes a completely stock 1988 GTA and gets it to run low 14's with VERY BASIC mods. Email me and I will scan the article for you and send it. I think this is what you are looking for. JosephAndres@aol.com
Joe
1988 GTA 5.7L TPI Auto
355 ci. block,TPIS ZZ-9 Camshaft, SLP Headers, Borla Cat Back, B&M Holeshot 2400 Stall Converter, 3.73 Richmond Gears
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Joe
Start with a tuneup, if you havent already. Replace the air filter, fuel filter, spark plugs, spark plug wires, etc. Then read the tech articles on this website, starting with this one:
https://www.thirdgen.org/newdesign/tech/tpimod1.shtml
Assuming you race at a sea level track, your car should aleady run 14's. Here in SoCal, we have several stock or mild modded GTA's running 14's on street tires.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
thanks again Zack, Joe and Kevin!
low 14's means much more horse power than stock 230hp? anyway, i cant wait to get in garage and start making all the mods you already told me
i just hope i wont ruin vacuum and screw up the computer. i manage to do it with S-15 truck, coz i changed too radical cam
this time i wont open the whole engine, i rather drive those days than trying to open stucked header bolts
later. 1:20am now...
Exhaust...gut the cat, or just bypass the cat and mufflers with pull out plugs.
Air induction...k&n does help, screens I am not so sure.
Timing, good gas.
I did 14.1s to 14.3s with only a K&N and aftermarket exhaust (no cat.) on 93 octane with f*c*e* up timing.
And your GTA weighs too much...throw out some stuff (spare tire, seats, radio, A/C, ...) Get Rid Of It All...and try washing it.
1989 GTA Trans Am
Gunmetal Metallic, T-Tops
L98, 700R4, 3.27
Timing, good gas.
1989 GTA Trans Am
L98, 700R4, 3.27
There is info on the mods I made to my '87 Formula 350 to get it to run 13.94@96.67 on the website below. Also exact pricing for everything I have done to the car. It wasn't exactly cheap, but it was worth it I don't think the free mods will get you into the low 14's
Best of luck
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Best of luck
A cat-back exhaust system can be purchased for minimal amount of money and can make some serious gains in your car. This is also a good mod to do since its very easy to install. I would recomend the Hooker cat-back system, I got mine from Jegs for $260, and I installed it myself in about an hour and a half.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
If your car is slow then their is something wrong with it and or it needs a tuneup.If you have a dualcat car,you should be running mid-low 14's stock.I ran 14.3 stock with just a tuneup,and am running mid 13's with some free mods and basic boltons.How does your tranny shift?You can go to the site in my sig,and you can see my writeup on what I did to mine for some ideas.
1990 Trans Am GTA,Black/Black Leather,350,auto 3.23,Dual Cats,
SLP Package,SLP Torque Converter/Shift Kit,Fastchip,GSC's
G-tech 0-60 5.1 1/4mile 13.6@104
member www.transamgta.com
Previous Thirdgen
1986 Camaro IROC-Z
Previous Thirdgen
1986 Camaro IROC-Z
hi Guys!
my GTA is not that slow, in fact it runs whole lot better than any car i had before but i never had car which runs good enough Joe sent me the article and it looked good. i'm not comfortable with idea to remove A/C or such a things, but relocating battery and removing the impact bumpers inside the covers would be nice?
maybe i do cat back by my own replacing original muffler with free flow one. 260$ is too much since exhaust is in good shape (not even rust). Summit catalog doesn't know K&N for firebird, just for camaro... do you have idea how much does it cost?
once i order something from states it takes weeks and i have to pay 30% taxes before i get gadgets out from custom.
previous owner has took off the cat already. i'm not sure though do i need to put it back for annual inspection. hope not.
at least i have to order fuel/air and fuel pressure meters. cyberdynes looks bargains and i can place those to dual pod so i can monitor what's going on while driving.
i try to set stock pressure regulator by placing coins inside it, have u tryed it?
car really weight 3800lbs, coz it's fully loaded with everything i can imagine except roof console =)
roads are still cold and slippery here (this is like canada or alaska i guess) cant test mods, but i can make those
i think this post tread will help many budget modders. i take a look to your mods. great forum!
98_1LE:
i checked your mods and those made lot of sense. IM NOT SHOUTING JUST COMMENTING OK?
Upper plenum ported behind throttle blades
YEP
160º thermostat
NOT TOO EXPENSIVE. HOW'S 180?
Comp Cams polymer Air foil
YEP YEP
Removed MAF screens
NOT SO SURE. IS THAT MANDATORY OR MUST MOD? ANY HARM OF DOING IT?
Bypassed the coolant to the throttle body
HOW DID YOU MANAGE TO SPEND 7$ FOR IT? NICE MOD ANYWAY
Brass insert cap & rotor
AC plugs and Taylor 8mm spiral-core plug wires
OK
HyperTech Thermomaster chip
HOW MUCH THIS HELP? WITH THAT PRICE YOU COULD HAVE PROGRAMMER? AND WE ALL SEEM TO HAVE PC
Relocate the MAT sensor in front of the throttle body
DID YOU USE SOME RELOCATION KIT? WAS IT WORTH?
Set timing to 6º BTDC
YEP YEP
SLP 2OTL muffler/tailpipes
I'LL DO SOMETHING MO CHEAPO
JET adjustable fuel pressure regulator @ 45 psi
COINS WOULD BE NICE DIME OR TWO
good ideas... d*mn! i got to get in garage soon!
i'd add underdrive pulleys. that mod is not so cheap, shorter belt only (for s-15) cost me 60$ here in Finland. i can swear i noticed the difference (voltage dropped at idle) seriously it makes better mileage and add power for sure.
Dude?! whats with that name?!!! FbodySucks?!!!
where do u get the idea that a K/N or an Air foil is expensive? A weeks worth of gas is more expensive than either on of those!
get a k/n, air foil, cut out the MAF screens, put on a Flowmaster 80 series, tune up, and all the rest of the free mods on this page.
if you have the air filter compartment in passenger side fender well, i got an extra K/N for that type, and an extra Air foil i sell them both to ya for like 30 bucks, they r just sitting around and i want to get rid of them. I could send em next time i come home from school if u r interested. E-mail me if u want em. And change that friggin NAME!!!
89' Firebird Formula WS6 L98, MSD 6AL MSD Blaster, Hypertech chip, K/N filter cone,flowmaster 80 series, hypertech air foil, koni shocks, edelbrock trailing arms
more to come soon.....
My temporary P.O.S. website: www.angelfire.com/il3/DuPageSpeed
take it easy! i'll change nick for something else just to make you happy ok? maybe "iluvmustang". anyway, do you know humour type called sarcasm? i wont hang around here if i really dont like the car i just bought at $$$$$.
anyway, i'll share the experiences with all of you once i've done the mods. k&n is not worth of its price, clean paper element is not that much worse. i had k&n in my truck and honestly there was no difference what so ever. only cam and heads did something. nothing much though
school boy
10-22-2015 11:47 AM
bigjay89gta
10-15-2015 08:04 AM
Royal_Z
09-30-2015 08:45 PM
