Injector's 19lb vs 22lb
Old 09-28-2007 | 05:25 PM
CamaroSpeed's Avatar
Car: 1987 IROC
Engine: 305 Tpi
Transmission: 700r4 With B&M Rebuild Kit & 2800 S
Injector's 19lb vs 22lb sorry for double post
can i run 22lb injector's in a 305 87 tpi camaro and if i can what pressure should i run on adjustable fuel reg sorry for double post
Old 10-02-2007 | 03:02 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: Injector's 19lb vs 22lb
Hey I'm no tuner but I believe if you use the 22's instead of the 19's you need to have a chip burnt to change the injector constant. Then I would start with stock pressure (42PSI I think) and go from there. If you want to try it without changing the program, then I would go with less pressure to start with. I think you'll have problems though.
92-Formula
12-12-2015 11:34 PM
rubyred88
09-17-2015 03:19 PM
thejimsterz28
09-15-2015 05:37 PM
BAMiller
09-14-2015 07:38 PM
webeeZ28
09-14-2015 01:00 PM
