Issues after new motor install
Old 09-26-2007 | 04:08 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
long story short.. i have a 88 trans am that had 203k miles on it.. so i got a crate 350 put it in and hooked everything up. now magicly my key switch does not go all the way to start... my fuel pump worked twice, now nothing. and i know my starter is not hooked up right...
issues-
starter... here are the wires i have going to it- battery cable, 2 red wires with a fusable liknk 1 purple wire, and then 2 more red wires, that are spliced together into a blue wire. what goes where?
key switch... did it just go bad or is something wrong? i can get the ign. to the "run" place... injectors have power and coil has power
fuel pump... all i want to know is does the cpu controll it at all? i noticed that on my cou i have a white wire not hooked up to anything..
car is a mess.... any help and further questions would be appreciated.
Frozer!!!
01-19-2024 04:55 PM
theshackle
09-17-2020 08:26 AM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
fonzie85
08-13-2015 11:50 AM
Quick Reply: Issues after new motor install
