how does the ZZ4 cam idle
Old 03-10-2001 | 01:30 AM
98_1LE's Avatar
Is it choppy?
87 Formula 350 13.94@96.67
98 Z28 1LE 13.15@107.59
1LE Owners Association
Old 03-10-2001 | 02:35 AM
Dan87IROC-Z's Avatar
My LT4 HOT Cam is noticeable with the car is in gear, but when its idling in neutral or park, it runs like the stock cam. I have stock heads and intake. I'm sure the ZZ4 cam being smaller than the LT4 HOT runs even better!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old 03-10-2001 | 07:45 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
It's got a tiny bit of a lope to it - enough that it is noticible with a free flow exhaust system, but not "choppy".
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
Old 03-10-2001 | 01:21 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Mine sounded like Lee's, it has a little bit of a lope sound to it but it was very nice sounding.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old 03-10-2001 | 08:30 PM
SpankuGta's Avatar
Ill be able to tell you next saturday and the following week ill be out at Ennis if you wanna hear it.
88 GTA 73k miles
Flowmaster catback,Random tech high flow cat,Ported plentum,Hypertech afpr and air foil,cold air induction,Msd blaster ss coil,cap and rotor and Super Conductor wires.Best ET 1/8th 9.21 at 77 mph.All mods were done within two weeks after purchase.
Old 03-11-2001 | 06:45 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Ditto to what Kevin and Lee said...idles good even with a stock chip
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old 03-11-2001 | 10:16 PM
Drewcifur's Avatar
Car: 1989 Firebird Formula
Engine: 350 ZZ3
Axle/Gears: Stock
Hey Iroczz3 were you pleased with the lt4 hot cam when you put it in? I'm thinking about getting that cam and finding some heads to match. Thanks
89 Formula 5.7L
ZZ3 with some good mods
Old 03-12-2001 | 08:58 AM
IROCZZ3's Avatar
Car: 87 Buick GN
<font face="Verdana, Arial" size="2">Originally posted by Drewcifur:
</font>
Sorry I don't have the hot cam, just the ZZ3 cam...
But, I'll be swapping in an LPE 219 cam in a few months.
lt500r55
09-01-2021 02:30 PM
Street Lethal
04-30-2019 01:14 PM
italiano67
12-11-2016 10:21 AM
bamaboy0323
09-03-2015 07:07 AM
camaro71633
09-01-2015 11:24 AM
