91 tpi no spark
91 tpi no spark
heres the deal ......
91 305 TPI
MSD btm
MSD Blaster 2 coil
MSD wires
new distributor (last summer)
last week I pulled off my coil wire and cranked the engine til I got oil pressure then put the wire back on and then no start. so I left the car for afew days thinking I flooded it and still no start..
I changed the coil no good .
I have a trigger pulse going into the coil.
I also bypassed the MSD and no good still!
what else could it be guys?
Fuse?
91 Black Pearl Z
5 spd
low miles
9psi ProCharger
3 row intercooler
paxton BTM(MSD)
MSD blaster2
ROH Snipers
Drilled rotors
350rwhp/400rwftlbs 305 Baby!
The Darkside
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
If your still using the ignition module, that is what I would check next. I had 1 blow on my Z. I was just driving down the road and it just died. After replacing the coil, cap, roter, wires, and other things, I replace the module. Started like a bat out of hell! Those things are known to die because of heat. Hope that helps!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
<font face="Verdana, Arial" size="2">Originally posted by sonnyb:
I had a problem like yours in my 1991 z28. It was the neutral safety switch that is located in the console attach to the shift lever. </font>
I'd look at that ignition moduele too, it's probably what the problem is.
that happened on mine and it was the ignition pickup module, its either that or the ignition module.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
litemupp
Southern California Area
08-23-2015 10:09 PM
Sanjay
08-12-2015 03:41 PM
