top speed limiter removal
Is there a way to get rid of it without having the service light come on? I know, not all 92 models had it. Would I have to get a ECM from one of those cars? Kind of odd that I have it on my Z-28. Dumb thing to do to a sports car.
1992 Camaro Z-28 5.7L auto t-tops arctic white
1967 Pontiac Catalina 2 door fastback 400 v-8 auto cameo white dark red interior
Car: Death Mobile
Engine: 666 c.i.
The AUJP eprom for L98s do not have a speed limiter. Are you sure that the eprom is from an L98? Only 305s w/o Z rated tires got a speed limiter. What is your VIN#?
You can check your epromo by pulling your ECM and looking at the "broadcast code" sticker on your ecm. You should see a bunch of numbers and somewhere there will be an 8 digit number that has 4 letters followed by 4 numbers. You car would have an "AUJP1350"; the replacement from GM is "AUJP1615" for about $60.00.
If your sticker is missing; this would be suspicious but you can still get it by looking at the erpom. Pull it and you should see a "silver square" sticker under one of the openings on the blue cover. If you have to, remove the blue cover. Then you should see the 4 letter/4 number broadcast code.
Yeah, My car originally came with a 305. So if I buy that part from GM it will get rid of it completely? The car also has a electronic speedo.
Thanks, I can't stand topping out at 110mph. Actually I'm so excited that I'm going to get part right now. Just wish there was tracks closer to home.
Well, I went and bought the part it will be here tuesday. It cost about $75.
Car: Death Mobile
Engine: 666 c.i.
Depends on the dealership and the taxes in your state/province. Around here one place wanted C$90 (about US$60) without taxes and another (where I use to live) gave me a deal at C$60.00(about US$40)...provided I teach them what I am doing.
Unfortunately it cost $60.00 in gas to get it, but I was visting friends and family, so that was irrelevant (this time).
They could'nt find the part number that you gave me, but they knew what I wanted. So it was'nt too hard to find. It kind of sucks they did'nt have it in stock.
Car: Death Mobile
Engine: 666 c.i.
No, Rod has the 5.7 (350). A 350 eprom would tend to run too rich in a 305 and all 350 eproms are for automatics. I believe in 1992, if you car came with V rated tires, it got a speed limiter where as cars equiped with Z rated tires got the eprom without the speed limiter.
Rod, if the memcal does not say AUJP1350 or AUJP1615, don't take it. Also, I would be curious what the "broadcast code" was of your existing eprom. If you remove the ecm their will be a sticker on it which will have a part number starting with 1615xxxx and a 4 letter/4 number "broadcast code".
I should have just pulled my ecm and told you the "Part number".
The part I ordered came out to be the AUJP1350, we were looking for the other part number you gave me. I took out my original, but did'nt right it down. It had ?XXB-????. When I get a chance to take it out I'll post it here.
Okay the original chip is AXXB-3063 w/speed limiter. The part number I ordered was AUJP-1350, and the part I recieved was AUJP-1651. Same part. The car even has little bit more snort. Won't know if it took it away until this spring when I take it to the track. But I'm going to take your word for it. I can't see why it would'nt work. Thanks again.
1992 Trans Am
05-10-2023 07:19 PM
1992 Trans Am
08-08-2015 08:16 PM
