ZZ4 cam paint.
Old 09-04-2007 | 02:46 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
ZZ4 cam paint.
I got my ZZ4 camshaft a few days ago and I noticed the paint is flaky and doesn’t stick well to the cam. I looked at the back and the #'s are all there with 071 part number so I don’t think it’s a fake and why would anyone want to make a fake ZZ4 cam shaft? Anyways I don’t want paint flakes in my engine when I get it running again. So I’m wondering if the paint should be so flaky? And if it should be I’m just going to remove the paint before I put it in.
Old 09-04-2007 | 03:49 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Re: ZZ4 cam paint.
Are you referring to the paint between the lobes? If you are, you can sand that away. JUST BE VERY CAREFUL NOT TO KNICK A LOBE, if you do, you will have far greater problems.
Old 09-04-2007 | 03:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: ZZ4 cam paint.
Brush off whatever's lose, rinse off whatever will come free with solvent, and don't worry about it.
Old 09-05-2007 | 06:15 AM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
Re: ZZ4 cam paint.
just get a blower and a air hose and shoot off any loose paint with high pressure air
Lanz06
03-13-2019 06:07 PM
Jorlain
10-08-2015 01:57 AM
Lanz06
09-14-2015 07:16 PM
Strick1
09-04-2015 07:11 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: ZZ4 cam paint.
