Valve Lift on Stock 305 Heads?
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I was looking at swapping the stock cam in my 89 305 TPI for an LT1 cam. The LT1 cam has a .450" lift.
Will the stock springs on the 305 heads handle this?
What is the lift on a stock 305 spring?
Thanks...........Bill
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Re: Valve Lift on Stock 305 Heads?
Maybe someone else can give you the exact answer but I have 305's heads on my 355 and the cam lift is .470" with the stock 305 L69 (shimed) springs.
Auggie
Auggie
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
They may handle it but there's absolutly no point in putting those springs back in when you're already in there swapping the cam. Just buy a set of the Elgin/Pioneer ".550" max lift springs, even the ".500" max lift springs will work.
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I read some where that the adverage stock spring can handle about .490" lift
The stock springs on most SBC heads can easily handle .500 lift BUT.... they lack the pressures necessary to control anything like a "performance" cam. They're marginal even for a stock cam.
The REAL limit on stock heads is that the retainers typically hit the guides/seals around .470" lift. So you need to stay under that unless you do some machine work to the heads, regardless of what springs you put in it.
Comp 981 springs are a nice upgrade over stock and drop in place of stock without any machine work to the heads. I've used them successfully with both performance flat tappet cams and mild hydraulic roller cams, like the LT1 cam you're considering.
Car: 89 IROC
Thanks...........I will be putting in a 355 or 383 in a few years and will buy decent heads with good springs on them.
This is why I didn't want to buy springs now, as it seems like a waste of money. If I can get away with the stock springs with the LT1 cam then I am ahead of the game.
