HELP! question about 02 sensor/fouled plugs...
1 Post
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Car is ZZ4TPI, 24# injectors, MSD6AL, 1 5/8 headers. Noticed the car running crappy last night. Pulled 1-3-5-7 plugs, kinda dirty, maybe an over-rich condition. pulled 2-4-6-8, completely black. Since the O2 sensor is on the 1-3-5-7 side, could this have something to do with it? I did have to lengthen the wire on the O2 sensor to clear the headers. I've heard this screws up the sensor. I cleaned the plugs and want to fix the root cause rather then run it today and have to clean the plugs again.
I'm betting O2 sensor. I didn't pull any codes out of the computer, I hit my battery kill switch to do the plugs before I could.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
1 Post
Engine: ZZ4TPI
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
[This message has been edited by Rob P (edited January 28, 2001).]
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Sounds rich to me on both sides. Do you have a scan tool to see what the O2 readings are and crosscounts?
Crosscounts should cycle from 0-255 in under 90 seconds, if not, then you have a weak O2. As far as the wire, whether the wiring harness or the connector wire is lengthen, I don't think it matters, wire is wire no matter where it is added.
Maybe fuel pressure too high, do you have an adj fp reg? Any exhaust leaks before the O2 sensor, that can cause the O2 to see a lean condition and make it run richer.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, highly modded
95 Trans Am Conv.- LT1
Rob
1 Post
Engine: ZZ4TPI
Unfortunately no scan tool. Had a friend over the other day from the SeThirdgen board. He's a GM Tech. We think it may be a faulty adj FPR. It seems to stick sometimes, i.e. I turn to adjust the pressure and see no change on the gage. If I move it far enought it will jump eventually. Probably gonna get a new adj FPR and see if that does the trick.
I had thought that adding wire to the O2 sensor might add unwanted impedance or resitance to the signal coming from the sensor.
tks
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
tks
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
If I'm not mistaken the sensor wire is of a different type.(alamel or chromal wire) Lengthening or shortening of that wire WILL cause a faulty reading.
