Looking for Pics of Coolant Temp Sensors on TPI Heads
Hey guys... can you get me a pic of the coolant temp sensor, and coolant temp switch... one is located at the front of the Drivers side cylinder head, and the other at the rear of the passenger side cylinder head.
I would prefer to see them on '89 & Up... just in case they changed them.
Thanks,
Dave
Thanks,
Dave
Car: nissan titan and nissan hardbody
Engine: 305 tpi
Transmission: manual
Re: Looking for Pics of Coolant Temp Sensors on TPI Heads
here's a pic of the switch from tpiparts.net
Engine: 305 tpi
where is it SUPPOSED to go? fine question, mine is in the driver side. in my passenger side is the sensor for my autometer guage and the rest of the coolant sensors (cold start and coolant temp) are in the front of the intake manifold.
See, that's my challenge... From what I can tell... according to the service manual... the Pass Rear is the 'Coolant Fan Switch' (what you have pictured here)... and the Drivers Side front... is the 'Coolant Temperature Sender' which uses a button style end of the sensor... and sends the temp reading to the gauge. I'm just trying to locate both proper sensors... and then wires. Thanks for any addt'l pics... (A Stock Car may be a bit better for this pic if possible). Dave
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Sanjay
08-12-2015 03:41 PM
