Are all TPI plenums EXACTLY the same in 85-92?
I'm thinking of buying a plenum to polish and port so I dont have to not have my car for a week.
Are they exactly the same. With vacuum fittings..weatherpack connections....basically everything?
91 Formula
305 TPI 5speed
1LE/G92/WS6
K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(47psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
No, 85 - 89 are the same, and 90 - 92 are the same. The only difference is the 90 and later ones had the provision for the MAP sensor.
Black 88 GTA L98
New engine is in!
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back
E.T.F.A Member #11
Black 88 GTA L98
New engine is in!
E.T.F.A Member #11
85-88, and 89-92. I replied to your other post in the history/restoration forum.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The 90-92 plenums have a smoother radius inside,around the plenum to runner holes from the factory. The 85-88 plenums have alot of sharp edges inside. And the wall at the front is smaller on the 90-92 plenums.
I compared an 88 to my 90 and was surprised at the difference.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited January 12, 2001).]
Sanjay
08-12-2015 03:41 PM
