My engine is not making REV's above 4000 RPM...any Idead?
Hey guys. Heres the problem. My 1987 TA GTA, had a MAF crap out last summer. It was original. I changed it with the wells model which im sure most of you are familiar with. Anyway since the swap, my car has developed some sort of hic-up. I can't get the engine above 4000RPM when it's cold. (I mean engine cold not outside air temp). This happens in any gear and in Park or Neutral. It will not rev over 4000. If you put your foot to the floor it starts bacfireing and farting and popping, the car starts surging like someone driving a standard bad. Sometimes I can Smell raw fuel and see brown smoke billowing out the **** end. But....When the engine comes up to normal operating temp, the problem seems to go away. Please...someone have an answer for this problem. Thanx.
1987 T/A GTA 5.7L, Bored .020 and ported for .202 valves, edelbrock headers, flowmaster exhaust, JET STAGE II chip, Comp CAM, Adjustable fuel pressure, Airfoil, K&N filter, B&M stage 2 shift kit, and a home depot ram air(Hey it looks good)
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Ok, first of all, it's NOT your MAF sensor causing the problems! I replaced the MAF on my car and did't have that problem! 2nd....I HAVE experienced the problems you are having right now! The only suggestions I can give you are these! 1. Have the Module checked! 2. Check your timing and 3. Check your fuel pressure! I've had this problem TWICE...the first time it was the fuel pump going bad....the 2nd time it was the timing was WAY off!! If all else fails, just remember it's a small block CHEVY!! LOL!
1986 Trans AM
305 TPI
Completely Stock
Soon to upgrade to a 327 TPI with pocket ported 64CC heads, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
1986 Trans AM
305 TPI
Completely Stock
Hey man,i went through the same exact problem.It wound up being my firing order.The car ran fine until it got to a certain rpm where it wouldnt go anymore past that rpm and it just popped and backfired.It was just 2 of my wires mixed up going to the wrong sparkplugs.It wasnt a bad enough goof up to make the car idle bad but when you gave it gas i had the same problem.
Al in NJ
86 Trans Am 305 TPI,Bored 30 over,Blower Cam,Fordged Racing Pistons,High Volume Oil Pump,3" Flowmaster Exhaust,Hypetech Coil,Acell 300+ Race Wires,Bosch Platinum +4 Plugs.Best Et was 12.5 with a Paxton.
Al in NJ
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
I had a similar problem but my car also sounded funny out the exhaust,my cat was cloged,it had melted down internally right after I put an aft. market chip in(running to rich can do this to a cat)I hollowed it out and the car ran great
89 FORMULA 350,WS6 SUSPENSION,FRESH 355 MOTOR,TCI 12" STREETFIGHTER,TRANSGO SHIFT KIT,3.70 GEARS,SLP REAR CONTROL ARMS/PANHARD,HOTCHKIS STB,FORMULA GP'S,FLOWMASTER EXHAUAST,58 MM BBK,MINIRAM INTAKE,ALL FREE MODS(HEADERS WAITING IN GARAGE)SLP 3/4",NO CATS,
theshackle
09-17-2020 08:26 AM
