Bad bog when in gear. Please help
I just bought a 89 iroc with a LB9 and 700R4 with 140k miles. When I start the car up it runs great but when I put it in drive or reverse it bogs down really bad. What do you think it could be. A couple guys at the local chevy dealership said it was the cat.
Re: Bad bog when in gear. Please help
Did you scan for codes? How is your TPS setting? Did you clean out the throttle body? Replace your IAC? Run a vacuum test? How's your fuel pressure? Are you getting spark to each and every cylinder? These are just some of the things you'll need to cover first before member's can make a valid suggestion....
