VATS question
Old 07-23-2007 | 05:44 PM
Chet's Avatar
Car: GTA
VATS question
Quick question, if I can hear the fuel pump prime with the key in the "on" position does this rule out a VATS issue?
Old 07-23-2007 | 06:34 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: VATS question
Mine works like this. Turn key on security light stays on for maybe 10 seconds and goes out. If it stays on then vats has issues.
Old 07-24-2007 | 01:17 PM
DZcode's Avatar
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
Re: VATS question
VATs does not control fuel to the engine, it controls spark.
I swapped '730 speed density ECU TPI with VATs into my 69 camaro. The fuel pump would prime for two seconds everytime I turned the key, but the engine would not start until I turned VATs off in the bin.
stalkier
12-06-2015 11:25 PM
WIzmo
08-30-2015 02:30 PM
ezobens
08-19-2015 10:29 PM
redmaroz
08-16-2015 11:40 PM
stalkier
08-13-2015 12:59 PM
Quick Reply: VATS question
