CODE 32 , problem
CODE 32 , problem
Well , i changed the egr valve and the vacuume soleniod , and the engine just came back on , i dont know what the code is but ill put money on it that it's 32 , i have no ideas left ????
Well here is my delema , about a month ago i got an error 32, well i replaced the egr valve , and for a week it seemed fine , then it came back after reading a buch of manuals and info from everyone here, so i replaced the vacuume solonoid last night , went for a drive it was all fine until i was on my way home, it came back on.... the only thing i can think of is either the vacume lines need to be replaced , or the soloniode isnt getting power.. if anyone els has any info i would greatly appreciate it.
Pino
91'Formula
LB9 305 TPI 5-speed
http://www.geocities.com/MotorCity/Garage/5654/mur91.jpg
Pino
91'Formula
LB9 305 TPI 5-speed
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Jeeez Pepino, just like you to have your laundry out when you took the pic!! And you bumped down to a formula? Yeesh!
I'll try and email you sometime this week coming up and I'll have you come by the house so I can peek at it. IIRC '91 does not have a temp sensor on it, but have you thought to check your MAP sensor? It may not be detecting the drop in vacuum. Another thing to consider is carbon fouling in the tube and in the manifold and heads. I'll try and get in touch soon.
"The people always have some champion whom they set over them and nurse into greatness... This and no other is the root from which a tyrant springs; when he first appears he is a protector.
-Plato
-Plato
thanks Red devil,,, hey do i know you , iv had the formula for a while ,,,
Pino
91'Formula
LB9 305 TPI 5-speed
Pino
91'Formula
LB9 305 TPI 5-speed
Car: Tree Huggers
Engine: Do Not
-Plato
CODE 32 resolved, well i set the car away and i got it back it turned out to be the wrong type of egr valve , something about a positve or negative , i forget , but it works . The thing drove me nuts for a month , I would never have figured out to replace it again , i had allready replaced twice.
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Eibach Pro-Kit Springs
Hotchkiss STB
SLP exhuast
SLP Cold Air Induction
CatCo Hi Flo Cats
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Hotchkiss STB
SLP exhuast
CatCo Hi Flo Cats
