TPI Supercharger Boost retard help
I need a boost retard box for a 89 trans am v8 5.7 TPI with super charger ati p600b
anyidea where i can find it any website
recommendations?
thanks
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Re: TPI Supercharger Boost retard help
MSD 6BTM you can get it at summit or jegs and ebay
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
You should learn to burn your own chips. You can swap to the 749/730 ecm and run the cylclone/typhoon code that is designed to run with boost. This way you can properly tune the ECM for boost and due away with any add on boxes that really just crutches anyway. You'll have boost retard, full fuel control under boost, and with a little enginuity on your part you can even have the ECM control the boost.
toronto formula
11-10-2015 06:17 AM
Sanjay
08-12-2015 03:41 PM
