Comp cam recommended TPI cam...
Car: 87 Iroc Z
Part Number 08-502-8 which is a Comp XR269HR. Duration at .5 is 218, 224. Lift is .495 int., .503 exh. and a 112* LSA.
Anybody have this cam and what do you think about this for a 305 Tpi auto.
Re: Comp cam recommended TPI cam...
That is a big cam for a 305 and would go better with other mods such as an aftermarket TPI intake manifold, runners, 2400+ stall converter, and headers.
What other mods do you have done? If your car is mostly stock then you should stick with a camshaft that is in the 208/212 range.
LT1Formula
08-20-2015 09:36 PM
1988iroc350tpi
08-14-2015 07:52 PM
