I'm begging, please help me
I finaly got my car running (a month ago) and i'm have big problems getting it to run right. The car smells very rich and at 1700-2000rpms the car surges bad. I fixed all the vacume leaks I had and check the car with a scan tool and it looked o.k. I do have a Ed Wright custom chip in it so I wouldn't think it's the chip. Please help thanks.
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
1987 Buick Turbo-T
you didn't give us much info to go on. are you sure the tune up is good? no dead cylinders? fuel supply ok? tps adjusted correctly? all the injecters fireing?
-=ICON MOTORSPORTS=-
1st & 3rd
1st & 3rd
Like I said every thing seemed fine. It only happens when I rev the car slow but if I rev the fast the tach flies right past it with no problem.
1987 Buick Turbo-T
1987 Buick Turbo-T
Is your o2 sensor ok? What is your fuel pressure? Do you have an afpr? What happens if you use the stock chip? Where is your air intake? You can have big problem with air coming from the radiator fan.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Well I took the custom chip out yesterday and put the stock one back in and no more problems. Thanks for the help.
1987 Buick Turbo-T
1987 Buick Turbo-T
1 Post
Car: An Ol Buick
Engine: Vsick
If so gimme a holler off list.
Anyone else right around here?.
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I know that this is a late reply, but what about the TPS sensor. I had that problem on a stock L98. Just a note.
HybridZ
Aftermarket Vendor Review
01-15-2004 05:33 PM
