need a new MAF which is best to use with #24 injectors?
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
hey guys now i need a new maf sensor and i know this because i took the 1 from my dads Iroc and my car started up right away with the maf plugged in. With my Iroc 1 plugged in starts right away so my question is which maf should i get since i have the ford 24#'s will the stock 1 be good or should i get an aftermarket brand? thanks
87_gta
87_gta
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: need a new MAF which is best to use with #24 injectors?
Injector flow rate is set in the prom not by the MAF. I would go with a Bosh if it were me.
BumpaD82
02-26-2016 02:57 PM
